Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #391 (permalink)
Old 12-14-2007, 01:23 PM
mrcman58's Avatar
mrcman58 mrcman58 is offline
mrcman58 is starting off with a positive reputation.
Howdy all,
wow, 292251 verses 192251 for 6's, and 273088 verses 173088 for 8's.. a hundred thousand #'s off, I'am trying to check my sources to see if "back when" i wrote down a 1 insted of a 2 ?? on the info i gave, also now from what i have read here 2..... sounds closer to a cut off than 1..... does.
__________________
1935 1 1/2 ton 4sp V8, 1945 1 1/2 ton 4sp V8,
50 F1 4sp V8, 50 F5 4sp V8,
61 merc M100 3sp I6, 68 Merc M100 3sp V8,
68 Merc M100 4x4 4sp I6, 68 F250 4x4 4sp I6 hi boy,
69 F100 4sp V8, 69 F250 auto V8,
70 F100 auto V8, 70 F250 auto V8,
(2)70 F350's 4sp V8, 71 F100 auto V8,
72 F100 4sp I6, 75 F250 auto V8,
2000 F250 super duty 5.4,
  #392 (permalink)
Old 12-14-2007, 03:51 PM
texan2004's Avatar
texan2004 texan2004 is offline
texan2004 is gaining momentum as a positive member of FTE.
There should be some more number/letters on there. I think you found the first four digits of the firewall stamping we are referencing.
16 = Paint Code = Chrome Yellow
HP = Assembly Plant = Highland Park, MI
A = Month of manufacture/Assembly = January
The next digit or two would be the build date. It's also possible (and quite likely) that there is/are one or two digist between the "HP" and the "A". I'v eonly got one other HP firewall stamping so it's tough for me to recognize a pattern with this plant. Some put the date in front of the month. Others put the date in back of the month. Depnds on the plant and when the truck was built.
Regarding the purpose of the thread - it was originally started to determine the VIN # cut off between 1949 and 1950 model years. It's morphed into quite a bit more. The answer to the original question is "it depends". Engine and assembly plant are variables in determining what the model year is for a VIN number. Ford continued the VIN #'s in 1950 where hey left off in 1949 instead of starting over again. Actually the 49 numbers were a continuation of the 1948 numbers but the first digit in the VIN was an 8 in 48 and a 9 in 49. In 1950, they kept the 9 at the beginning of the VIN.
Recirds on the trucks were lost many years agom in a fire or flood so they are not avaialbe from Ford. Tim (mtflat) learned about the firewall stampings and shared that with me. What we've done now is collected a bunch of VIN's and fiewall stampings to try and figure out what were the paint codes they used and the 1949/50 VIN # cut-off.
Apprecaite you helping. yours is a key one becuase it's and early 49. As I mentioned earlier, it's the earliest 49 we've come across and it has a fiewall stamping.
__________________
2003 F-250SD, 6.0 PSD
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #393 (permalink)
Old 12-14-2007, 03:53 PM
texan2004's Avatar
Quote:
Originally Posted by 55 f350
i'll go out over the next couple of days as it's supposed to be warmer and spend some time cleaning off the " crap " on the firewall and cowl and get those if they are there . this might be kinda a silly question , ive only read part of this thread , whats this all about ???? is this like the early pinto's and the dain thing is gonna blow up on me ? LOL newsflash !! i went out after typing this and found some markings on the firewall . appears to be 16 hpa . this mean anything ? you guy's have got me real curious about it all .
You might want to cruise through it and look for some photos that have been posted of both the frame rail numbers and the firewall/cowl stamping so you can see what wea re talking about. Hopefully, we will be able to provide you with your truck's birthday. It looks like it's coming up next month so be ready to buy something for it
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #394 (permalink)
Old 12-14-2007, 07:00 PM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 is starting off with a positive reputation.
will do . its gonna be nice tommorrow they say so i might be crawlin ' around and when i get back home i'll try and find those photo's your talkin ' bout . gotta run!!!!!!!
  #395 (permalink)
Old 12-18-2007, 10:48 AM
55 f350's Avatar
1953 Ford F-100
i have wire brushed scraped etc. the firewall and parts of the cowl and no dice on any more markings as of yet .
  #396 (permalink)
Old 12-20-2007, 08:51 PM
r_reed r_reed is online now
r_reed is starting off with a positive reputation.
1. 1949
2. 98RG213116
3. raised panel bed
4. probably, not sure
5. 3 speed
6. floor shift
7. haven't found one yet
dick r
__________________
Dick R., East Glenville, NY
49 F-1
Keeping one more flathead alive
It smokes, but it's old enough
  #397 (permalink)
Old 12-21-2007, 01:08 AM
texan2004's Avatar
Quote:
Originally Posted by r_reed
1. 1949
2. 98RG213116
3. raised panel bed
5. 3 speed
6. floor shift
dick r
Thanks for adding your truck to this list.
The Vin # should read 98RC
9 = 1949/50
8R = 239 c.i.d. flathead V8
C = F1 (1/2 ton)
213116 - Vin sequence Number. Pretty safe bet this one is a 1949.
Would be great if you can locate a series of numbers stamped into the firewall or the cowl inside the engine compartment. This will give the build date, original color, and the assembly plant.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #398 (permalink)
Old 01-16-2008, 09:23 PM
55 f350's Avatar
1953 Ford F-100
texan got one for you to see if you can tell me about it . a fella on another website i frequent just bought this to save it from the crusher . its cool and outside of glass all there . it appears to be a 51 but it is an f-8 dumptruck . serial / vin jna81ah51-11726, engine code 1eq-11726 , model f-8 trim 14 paint 99 . i would as well as he , know what you got about this . i tried the vin decoder it said invalid . i am trying to come up with the cash to buy it as he didnt really want it just saved it from ahorrible death . 55 f350 .ak.a kevin
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
  #399 (permalink)
Old 01-17-2008, 12:15 AM
mtflat mtflat is offline
mtflat is gaining momentum as a positive member of FTE. mtflat is gaining momentum as a positive member of FTE.
That vin is Canadian - it is a '51 (just before the dash). that's why the vin checker drew a blank. Engine is 337 (1EQ)
I'll look it up tomorrow unless Carl beats me to it.
  #400 (permalink)
Old 01-17-2008, 11:38 AM
This website should help you sort it all out
http://www.mercurypickup.com/1948canadianvinplate.htm
As I read it: JN Canadian Ford F215/F8 159" wheel base/5 ton nominal rating, A standard trim, 81A cab and chassis, H built in Windsor, Ontario (Home Office), 51 1951, serial string
Engine: 1 1951, E(unsure), Q is 337 flathead with 5 spd transmission
  #401 (permalink)
Old 02-29-2008, 09:27 PM
gdgerland gdgerland is online now
gdgerland is starting off with a positive reputation.
3 more vin #
texan2004, Just got back from looking at 3 '50 Ford trucks. I am bidding on two of them but the third one is not for sale. I got the vin # from the titles but didn't have a chance to get the firewall stamping or the glove box data. If I win the bid on them I will add that info. This is what I found:
1950 F-1
I-6
Vin 97HC 282706
3 speed manual floor shift
raised bed
1950 F-2 (parts truck)
I-6
Vin 97HD 307167
4 speed manual (I think) floor shift
Unsure about bed (allmost dark)
This one is fully restored, not for sale
1950 F-1
Flathead V-8
Vin 98RC 336999
3 speed manual, floor shift
Smooth bed
Hope you can use this info. and will add more if possible.
Gil
__________________
1950 F-1, Flathead I-6
1980 F-150 S/B S/S
  #402 (permalink)
Old 03-01-2008, 02:06 PM
texan2004's Avatar
Thanks for the VIN's. Good luck bidding and would love to get the firewall stampings.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #403 (permalink)
Old 03-01-2008, 07:23 PM
Quote:
Good news, bid just closed and looks like I get the cigar! Will get you the rest of the info when I go to pick them up.
Gil
__________________
1980 F-150 S/B S/S
  #404 (permalink)
Old 03-02-2008, 11:45 AM
texan2004's Avatar
Just Curious - where are they??
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #405 (permalink)
Old 03-02-2008, 07:10 PM
They are located in Kingsbury, Texas. -----Did you go to the big Early Fords gathering this week end. I heard about it but had a family reunion this week end and couldn't go. I guess the San Antonio, Waco, and Houston area folks all get togather at one time. Should have been some nice rides there.
Gil
__________________
1980 F-150 S/B S/S
Tags
1949 , 1950 , 1950s , 49 , code , decode , decoder , ford , number , older , restoration , restorations , truck , trucks , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
