Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #361 (permalink)
Old 09-24-2007, 10:50 PM
texan2004's Avatar
texan2004 texan2004 is offline
texan2004 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by mtflat
Hi kid! Welcome to FTE. Your info is mostly right, but not all. The 49's picked up the serial numbers where the 48's left off. They didn't start over.
Your second paragraph has the general info, but Henry included as many exceptions to the rule as he did rules........ so it's all sorta-kinda. The book you're quoting isn't one of the most accurate out there, but it's a starting place. Stick around for the ride - it gets interesting!
We learn something new with almost every number we get. If we don't learn something new, we either get some sort of confirmation of what we though to be true or a whole new set of mysteries. In any case, patterns are developing.
__________________
2003 F-250SD, 6.0 PSD
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #362 (permalink)
Old 09-24-2007, 11:11 PM
texan2004's Avatar
Quote:
Originally Posted by gdgerland
1. 1950 F-1
2. VIN # 98RC323463 Branch MP (Data plate on firewall)
3. Bed = Raised panel ( I think) can see a line running along bed, humped over wheels. Fenders are off and in bed.
4. Unknown, but looks orig.
5. 3-speed
6. Floor shift
7. MPC8157B346 (stamped in firewall)
8. Engine # 878C139835 Model 8HC (data plate on inside of glovebox door)
Any more questions, please let me know.
Here goes best I can:
98RC 323463 MP
9 = 1949/50 (Safe bet yours is a 50)
8R = 239 c.i.d. flathead V8
C = 1/2 Ton F1
323463 = Vin sequence #. This one should certainly be a 1950
MP = Memphis Assembly Plant I only have three others from Memphis and two of them are 49's. More on the significance of this later.
Engine #: 878C139835 Model 8HC
What you ahve here is the glove box data plate from a 1948 1/2 ton truck that came with a 6 cylinder. Not original to your truck. I will add it to the list though so that we at least know where the glove box from this truck ended up.
Firewall Stamping: MPC8157B346
MP = MEmphis, TN Assembly Plant
C = ??
81 = ???
57 = ???
B = I berlieve this indicates a February 1950 build date.
346 = ?????
The other 1950 Memphis truck I have collected is:
VIN #: 98RC 451656
Firewall Stamping: MPC 81 20J330
The 1949 Memphis trucks I have use the same firewall stamping format that most of the other plants used in 1949 and 1950. In 1950, soemthin at Memphis apparently changed. As you can see the firewall stamping I have from another 1950 Memphis truck is a very similar format to yours. I thought the 20J indicated a September 20, 1950 build date. After looking at your number, I'm not so sure anymore but The J = Septemeber buid date would be about right on this VIN # just as the "B" = February would be about right for your VIN #.
I have no idea what the 81 indicates and I suspect the "C" is a paint code but I don't know what color it would be. Any clues to the original paint would be very helpful.
Perhaps our friend Tim from Flathead County, MT will have some idea.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #363 (permalink)
Old 09-25-2007, 08:30 AM
needhelp49 needhelp49 is offline
needhelp49 is starting off with a positive reputation.
it's funny i didnt know it was green after you said that i asked my mom and she said it was when grandpa bought it painted it black in the 60s me and the wife were talking about painting it green. so you answerd that ?
  #364 (permalink)
Old 09-25-2007, 10:10 AM
gdgerland gdgerland is offline
gdgerland is starting off with a positive reputation.
Thanks for the info.!!
texan2004, Thanks for the info on my '50. The glovebox door could have been changed at some point in time. The color on the frewall is a dark blue. The rest of the truck is black but looks like a bad repaint. Great data base, and you are right, I looked at all of the posts and not many MP trucks here.
Gil
__________________
1950 F-1, Flathead I-6
1980 F-150 S/B S/S
  #365 (permalink)
Old 09-25-2007, 10:29 AM
mtflat mtflat is offline
mtflat is gaining momentum as a positive member of FTE. mtflat is gaining momentum as a positive member of FTE.
Quote:
98RC 323463 MP
Carl, I agree with your comment about MP changing things. It was common in Canada to list the body code in the vin and since both MP trucks use the same 81 code, I'd bet thats what your looking at. 81 was body code for closed cab or cab/chassis.
C was also the Canadian vin designation for 110" wheelbase (F1 pickups)
Since both MP trucks were marked MPC 81 that might be the solution rather than color???
346 is the production vehicle down the line at that plant. I just don't know how they were assigned.
Only puzzle for me is the 57 before the B - something isn't right there. I'll keep thinking........... any chance it's 27?
  #366 (permalink)
Old 09-25-2007, 11:05 AM
mtflat, the 57B could possibly be a 27B. The truck is in Ft. Worth so I will check it when I go to pick it up.
Thanks, Gil
__________________
1980 F-150 S/B S/S
  #367 (permalink)
Old 09-25-2007, 10:00 PM
texan2004's Avatar
Thanks, Gil
IF it's a 27B then your truck has a build date o fFebruary 27. this would make some sense and would not be the first firewall stamping number to be misread. Sometimes they did a real nice job stamping these characters but I've seen some done very poorly as well. My 50 F1 is a classic example.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #368 (permalink)
Old 09-29-2007, 08:54 PM
mag409 mag409 is offline
mag409 is starting off with a positive reputation.
I just purchased a 1949 F6 and wanted to see if my information is correct. This VIN was provided to me as I do not have the truck yet.
Vin # 98R1H85531
I know the 9 is 1949/1951
8R is the 239 V8
I think the 1 and H may be switched.
Thanks Mike
  #369 (permalink)
Old 09-29-2007, 09:24 PM
49fordpickumup's Avatar
49fordpickumup 49fordpickumup is offline
49fordpickumup is starting off with a positive reputation.
Vin codes
I found a web site that gives body styles among much other information. I goggled :1949 ford 3/4 ton pickup then I selected the first choice of this search titled, http://www.mercurypickup.com/194950fordusbuilt.htm, have a great day,chuck
__________________
All gave some.....Some gave all.
1966-67
1950 F-1
1949 F-3 Donor
  #370 (permalink)
Old 09-29-2007, 10:22 PM
texan2004's Avatar
Quote:
Vin # 98R1H85531
8R is the 239 V8
Thanks Mike
Mike,
You are correct in that the VIN provided is not correct. Likely that has been misread.
9 = 1949/50 model year
1H = This likely supposed to be TH. If so, you have a 134" 2 ton F6. If you are certain it's an F6 and not a cab-over (C.O.E.), then I'm almost certain that "1" is actually a "T".
85531 = VIN sequnce number. This one is not correct however as theis number would have been assigned to a 1948. If you had a 48, your Vin # would have begun with an "8" instead of a "9".
You've got a little digging to do to find the correct VIN. Please post it when you get it. Also, please look at the cowl in the firewall area. There should be some numbers stamped into the metal (not a tag) that can provide some additional information like where the truck was built and what day it was built.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #371 (permalink)
Old 09-29-2007, 10:30 PM
texan2004's Avatar
Quote:
Careful with that site. Some of the information is correct and some is not. The 49/50's did not have body codes as this site would suggest although I am investigating whether Memphis may have included them in the firewall stamping. If this is the meaning of the mysterious "81" in the Memphis firewall stampings, then the information on this site is not correct regarding the body styles.
Also, the site mentions that the 1951 VIN #'s were a continuation of the 49/50 #'s until 9/15/51. I have yet to come across a single example of this. Ford went to an entriely different VIN # system in beginning with the 1951 model year trucks.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #372 (permalink)
Old 10-09-2007, 09:55 AM
Canarsie Kid Canarsie Kid is offline
Canarsie Kid is starting off with a positive reputation.
Texan 2004, you obviously have more information on VIN numbers than any book I can get my hands on, so here goes.
My firewall tag and dispatch compartment reads 90RO 399128 YEL
There is a stamping on my firewall: MBFF30391 (the first 3 could be an 8)
It's titled as a '50 1/2 ton (F1)
V8
3 speed on the floor
114" Wheel Base
Any help is appreciated.
Thanks
Canarsie Kid
  #373 (permalink)
Old 10-10-2007, 12:22 AM
texan2004's Avatar
V8
114" Wheel Base
Thanks
Canarsie Kid
For starters, I took a look in your gallery. That's a very nice looking truck. Would love to see more pictures. Looking at the front fenders, they appear to be the F2 and uip fenders with the larger opening. Not sure if you were aware that the F1 fendres were unique in that the wheel opening was smaler than the F2-F6 trucks. F7's and F8's had yet another size fender. All that aside, very nice looking truck. I envy you.
Recognizing that these VIN Tags can be a realm PITA to read, I will make a couple of rather safe asumptions with yours.
VIN # 90RO 399128 YEL
My guess is that this actually reads: 98RC 399128 ???
9 = 1949/50 model year (Base on the VIN, pretty safe you have a 1950)
C = 1/2 tom F1
399128 = Vin sequence number. Definitely a 1950
???/YEL = This would ordinairly be an abbreviation for the district/assembly plant. No idea what YEL would be but maybe we can figure this out later.
Firewall Stamping: MBFF30391
M = Color Code: Meadow Green
BF = Buffalo Assemly Plant. You should have found a BUF on the data tag where you are seeing YEL unless the YEL is some sort of special district code that would have trumped the assembly plant code being stamped there. I've read that this was done for some fleet or governement sales but I haven't come across an example ever before. Another possibility is that your data TAG is from a different truck. This happens sometimes. Yet another possibility is that the YEL may have been misread. Again these thing scan be a real challenge to read at this age. You can verify the VIN in two other places. The VIN # should be stamped on the top side of the top flange on the passenger side frame rail in the engine compartment. This stamping can be hard to read if the frame is rusted up but should be there. Another location for the VIN is the data tag on the passenger side of the firewall in the engine comaprtment.
F30 = June 30 Build date or F3 = June 3 build date. My guess would be June 30
0391 or 391 = some as yet undetermined plant sequence number.
Hope this helps. BTW, I don't know more than the books but I've read most of them and figure out what is consistent with what's realy out there and what isn't. One thing I discovered doing this was that the Somerville, MA plant buildt trucks. I've never seen this published anywhere when truck plants are dicussed but we have more than on exmaple of this in the registry. Tim, mtflat, has also been a big help having taught me (through this forum) about the firewall stampings. It's been an interesting exercise. I really appreciate the information.
One last point, if you have a Buffalo truck, they are pretty rare. I've only got one other Buffalo number. Either they didn't build many or the rust got them all. Perhpas a combo of both.
Evening Tim
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #374 (permalink)
Old 10-10-2007, 12:23 AM
Thanks
Canarsie Kid
Until Carl comes along, (edit: how crazy is that, Carl beat me posting by a minute - evening Carl!) this will get you going. Clean it up a bit more and I'll bet you find the firewall tag reads 98RC 399128. Definitely a '50 vin but I can't come up with anything for the YEL - should be assembly plant but doesn't jive with the stamping. ??
For the firewall stamping I'd guess:
M is color (meadow green in 50).
BF is Buffalo assembly plant
Next should be assembly date F30 - June 30?
Last three digits are for the car unit number down the line.
  #375 (permalink)
Old 10-10-2007, 08:09 AM
Thanks to you both. That's more information than I was able to find on my own. I bought it from a guy that gave up on it, who bought from a guy in upstate NY that gave up on it, so the Buffalo assembly may be valid.
I'll confirm with frame stamping and let you know.
Again thanks, I'll send along more pics. This site doesn't allow attachments. Forward e-mail and I'll be happy to send along. Thanks for the complement this is my first try at a truck. It's a driver and I want to keep it that way. I have done '55 - '57 T-Birds in the past and a few bikes. I wanted to get my son involved and a truck seemed like the natural choice for Father/Son project. It should look good in the HS parking lot when he starts to drive in Jan.
Thanks again
Best Regards,
Mike
Tags
1949 , 1950 , 1950s , 49 , code , decode , decoder , ford , number , older , restoration , restorations , truck , trucks , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
