390 vs. 400
you seem to be the only one. i never hear anything good about the stock heads
I almost put a 400 in my 71 F100.......I really believe all that motor needs to perform is a hotter cam and more compression......
my thoughts, the stock heads are the same as the 351c and they flow ok, for a crap design. the short side in a 90 angle, the valve sizes are good. the exhaust flows a little better than d2te heads. The timing is retarded on the 351m/400 from what i gather. Not to mention many had ac, smog pumps, and emissions oriented everything.
Back to the heads, they are open chamber design and it seems they can not tolerate any compression. You would need something like the aussie 2v heads to run a 9.5 cr. or a ****ty high duration camshaft, to bleed everything off.
As for aftermarket, thats a different game. The FE puts a hurtin on the 400 unless you buy custom intake adaptors.
FTE A.D.D member
FTE A.D.D member
I'll easily admit I have an FE bias, but I had a '79 F-250 with the 400 and a 4spd, (first a NP then a T-18), for many years and that was one strong truck. It sure had a lot of smog junk on it, but it didn't seem to hurt it any. A buddy of mine had a fresh 390 with a mild cam in a '73 F-250 and he couldn't catch me on the freeway. Sure had a lot more get up and go than the old 360 I have now.
Got 12mpg with it too and that was with a young man's lead foot. I miss that truck.
I have personally been pushing fords for over ten years and i prefer the 400 over the 390 it turns on quicker after some better pistons, cam,intake, and carb. I have one as my daily driver and i can chew up just about anything on the highway. And i am about even with a 390 out of the whole. They ar both stout motors.
i just reworked a 400 for a friend of mine and all I did was put on a performer intake and a 780 vacuum secondary holley with that powermax 266 cam and some headers.. the trucks are nearly identical for weight and we run the same tires. that truck of hers pulls alot harder out of the hole than my 390 but cant keep up at the top end. with the exception of intake manifold selection, parts seem to be more readily available for the 400, and400's are dirt dog cheap compared to the FE.. like gashog said though, they are not nearly as stout as an FE... being kinda hard on things i prefer the FE.. LOL
they are hard to find but there are flat tops out there for the 400 that will put you in that cr range without going to aussie heads...
