Are any of you running 20/50? - Ford Truck Enthusiasts Forums
Old 10-24-2005, 10:47 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
This is somewhat related to cbfomoco's post below, but since I have reported on it twice in other forums, thought to do so here.
I was using Valvoline 20/50 in my 292. Recently I replaced the crimped off overflow tube from the rockers, with a stock unit. Afterward, started the motor with rocker cover off, and waited and waited. No flow to the topend.
Alarmed, I shut it off after about 1 minute. Temp outside was 59 degrees and the truck was probably 50 degrees. Thought about it, and could think of nothing I had done to stop the oil. Started again and about 10-15 seconds later oil started flowing all over the place. The oil did have an additive, SciTech brand.
If you are running 20/50, my opinion and experience is it is not a good idea unless your motor is at the end of its usefulness. Also, the guys in the Oil and Lubrication forum, indicate that SciTech additive is a bad idea. Too little ZDDP and too many other bad side effects.
Old 10-25-2005, 12:40 AM
46yblock's Avatar
To the moderator, could you please delete this thread. I mistakenly doubled up. Thanks.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
