Engine Info Needed
Old 10-24-2005, 09:33 PM
farmkid's Avatar
farmkid
farmkid is offline
Engine Info Needed
I have a '74 F880 with a 477..I think. I have also been told it has a 475?? What are the differences and how do I tell what I have? The chassis VIN has been changed by the box manufacturer in '75 so I am not sure how to look up what the correct engine should be. Any help would be greatly appreciated.
Also, is the bolt pattern on the back common with anything else? The engine is in sad shape and needs a rebuild or a replacement.
Thanks.
Old 10-25-2005, 01:27 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,591 Likes on 1,296 Posts
According to other posts here, these engines had an SAE bell pattern, which allowed interchange with various truck transmissions, I'm guessing.
If you are going to use this truck commercially, I'd suggest repowering with a diesel.
Scroll down on this site for another swap idea.....
http://www.6066gmcguy.org/V6powered.htm
Old 10-25-2005, 06:35 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Thanks.
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 10-26-2005, 03:36 PM
Louisville Joe's Avatar
Louisville Joe
Louisville Joe is offline
I think a '475' is a '477'. In the 70's, the Super Duty engines came in the L and C series. The F-880 was a special F series medium duty with the Super Duty engine. For some reason, a 477 in an F-truck was a 475.
Old 10-27-2005, 08:37 AM
farmkid's Avatar
farmkid
farmkid is offline
Thanks. Is there any way to confirm this? Can I pull numbers from somewhere on the engine to confirm? I have a lead on a 477 and if it fits, I think it would be the way to go vs. repower with a diesel. I am not looking forward to changing mounts, tranny, etc.
Old 10-27-2005, 05:21 PM
HOTWRENCH's Avatar
HOTWRENCH
HOTWRENCH is offline
Talking Engines
Farm Kid
A "475" and a "477" are the same engine some times Ford played number games with the cubic inch designations. 534, 477 & 401 will all fit your truck.
Good luck HOTWRENCH
Old 10-27-2005, 08:31 PM
farmkid's Avatar
farmkid
farmkid is offline
Thanks for the info. Do you have an suggestions for improving the engine while I have it out? Just a little more power would be great. I am not greedy, I just want to get all of the power that is reasonably available out of it without going too extreme. How is the overall realiability on these engines? I think the old one has a bad head and I know it has 2 cracked exhaust manifolds. It should have had ~20K miles on it. I thought that it would have lasted longer that that. I'll know more when I tear into it.
Thanks.
Old 10-28-2005, 07:26 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking Info
farmkid
Back when there were lots of these engines around here , "coal trucks" the HOT setup was to disconect the govener, put a bigger carb on it , 780 hollys were popular set the timing up a couple of degrees, The factory exhaust was too restrictive , we used to make our own mufflers out of well casing. But whatever you do pay attention to the RPM's these old girls don't take any over revving !! 3400 to 3500 rpm's is about it.
I hope this helps HOTWRENCH
Old 10-31-2005, 05:55 PM
yalincoln2's Avatar
yalincoln2
yalincoln2 is offline
hello; in the mid 70's ford went from putting the intake runners in the head to an individual runner intake. the 475 is a 477 with the late heads. the 534 is the same engine with more cubes, if your changing engines the 534 has more power, the 477's were a little doggie in a big truck. the latter engine cools better and daul exhaust will help. if you use anything but a governed carb you should put a rev limiter on it, just my oppinion, wayne.
Old 11-04-2005, 01:16 PM
T850 FAN's Avatar
T850 FAN
T850 FAN is offline
I think that answers my question about the 475 SD in another thread I started last night.
Old 11-08-2005, 06:07 AM
Still in the 60's's Avatar
Still in the 60's
Still in the 60's is offline
The 475 was essentially a lower cost 477 without the warranty of the true Super Duty.
63flareside
Ford Truck Parts for Sale
06-17-2017 06:09 PM
Turbine Mechanic
Modular V10 (6.8l)
11-14-2016 05:39 PM
Wassup599
08-04-2016 09:01 AM
Lane Locke
04-29-2016 06:31 AM
Andy63
02-12-2003 07:10 AM
Quick Reply: Engine Info Needed
