You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a '74 F880 with a 477..I think. I have also been told it has a 475?? What are the differences and how do I tell what I have? The chassis VIN has been changed by the box manufacturer in '75 so I am not sure how to look up what the correct engine should be. Any help would be greatly appreciated.
Also, is the bolt pattern on the back common with anything else? The engine is in sad shape and needs a rebuild or a replacement.
Thanks.
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
I think a '475' is a '477'. In the 70's, the Super Duty engines came in the L and C series. The F-880 was a special F series medium duty with the Super Duty engine. For some reason, a 477 in an F-truck was a 475.
Thanks. Is there any way to confirm this? Can I pull numbers from somewhere on the engine to confirm? I have a lead on a 477 and if it fits, I think it would be the way to go vs. repower with a diesel. I am not looking forward to changing mounts, tranny, etc.
Farm Kid
A "475" and a "477" are the same engine some times Ford played number games with the cubic inch designations. 534, 477 & 401 will all fit your truck.
Good luck HOTWRENCH
__________________ FERGUSON'S GARAGE est. 1967 car , truck , heavy equiptment repairs 4 X 4 specialists PORTABLE WELDING SERVICE TOWING New @ used PARTS 1981 L 800 460 5 speed , 2 speed rear 1957 F 600 390 5 speed
Thanks for the info. Do you have an suggestions for improving the engine while I have it out? Just a little more power would be great. I am not greedy, I just want to get all of the power that is reasonably available out of it without going too extreme. How is the overall realiability on these engines? I think the old one has a bad head and I know it has 2 cracked exhaust manifolds. It should have had ~20K miles on it. I thought that it would have lasted longer that that. I'll know more when I tear into it.
farmkid
Back when there were lots of these engines around here , "coal trucks" the HOT setup was to disconect the govener, put a bigger carb on it , 780 hollys were popular set the timing up a couple of degrees, The factory exhaust was too restrictive , we used to make our own mufflers out of well casing. But whatever you do pay attention to the RPM's these old girls don't take any over revving !! 3400 to 3500 rpm's is about it.
I hope this helps HOTWRENCH
hello; in the mid 70's ford went from putting the intake runners in the head to an individual runner intake. the 475 is a 477 with the late heads. the 534 is the same engine with more cubes, if your changing engines the 534 has more power, the 477's were a little doggie in a big truck. the latter engine cools better and daul exhaust will help. if you use anything but a governed carb you should put a rev limiter on it, just my oppinion, wayne.
