Tow Command on trailer w/o brakes
What can I do to trick my F350 Tow Command to no show a fault everytime I hit my brakes on my little bumper hitch trailer that doesn't have brakes on it? I have 05 F350 CC SB FX4 PS. Really like TowCommand on all my trailers except this trailer without brakes. Any ideas?
If you have the tow command system your truck should have came with the 7 way round trailer adapter as well as a 4 wire plug next to it on the back of your truck. Are you saying that you took this off and replaced it with a 6 way round plug? If so why didn't you just buy a 7 way to 6 way adapter?
Anyway my guess is if you did rewire the connector you might have got a wire crossed somewhere. Otherwise maybe there is a mixup somewhere in the trailer wiring. Does your trailer have a 6 way plug? Are you using a 6 way to 4 way adapter? We need a little more info to try to figure this out.
Check this site for cross referencing the various plug wiring diagrams .....
http://www.easternmarine.com/em_stor...ch.html#wiring
[QUOTE=alchymist]Check this site for cross referencing the various plug wiring diagrams .....
www.easternmarine.com/em_store/tech_info/light_tech.html#wiring[/QUOTE]
Thanks, I had some diagrams but these are a little more straight forward. I think looking at these, I may have my 12v and auxillary's crossed. Everything else was pretty straight forward and works fine. I am thinking of hooking the auxillary to my upfitter switch to lights around the back of my trailers for backup lights.
vincewood30
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
13
04-19-2009 03:33 PM
1978 Ford
12-29-2008 08:36 PM
