How to adjust hood - Ford Truck Enthusiasts Forums
How to adjust hood
Old 05-06-2002, 01:51 AM
karljay karljay is offline
karljay is starting off with a positive reputation.
How to adjust hood
I'm re-installing my hood after painting and while I was trying to line it up, I noticed that I had to push the back down. I had to move to either side and push down on the hood in order to get it to go down.
I moved the fender to firewall bracket down as far as I could get it, then I moved the hood hinge down as far as I could but the rear of the hood is still too far up (about 1/2" or so).
the hinges are nice and tight and the springs are very tight (the hood doesn't sag down after you lift it.
any ideas about why I have to push the hood down in the back?
thanks, Karljay.
Old 05-06-2002, 09:54 AM
4rdgasm 4rdgasm is offline
4rdgasm is starting off with a positive reputation.
Post How to adjust hood
hey there, i ripped my hood off one winter to do some work under the hood, had the hinges chromed, etc. Basically the hood springs were left in an open position for long period of time. when the hood is open, the springs are in a compressed position, and naturally, when you shut the hood, they are stretched open. the springs "get used to being compressed", so to speak, so their tendency is for them to try and return to a compressed position. Give them time, they should settle back down. I know mine did.
Old 05-06-2002, 11:35 PM
stephenw stephenw is offline
stephenw is starting off with a positive reputation.
How to adjust hood
I recall dealing with the same puzzle on my hood many years ago. What I finally came up with was that the hinge mount onto the cowl needed to be RAISED, not lowered, to make the hood match up. It's something about the way it articulates, and very counter-intuitive. Anyway, try that VERY CAREFULLY just in case my gray matter isn't still intact, and see what happens. You will probably have to adjust the hood toward or away from the cowl also before you are done. This assumes that you have already oiled up the pivots on your hinges so they move freely, of course?!? Steve
Old 05-10-2002, 03:22 AM
luv70sfords luv70sfords is offline
luv70sfords is starting off with a positive reputation.
How to adjust hood
Old 05-10-2002, 03:52 AM
How to adjust hood
Thanks, I'll give it a try and see what happens...
Old 05-10-2002, 09:18 AM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
How to adjust hood
Next time you have to take off your hood, do this trick:
Drill an 1/8 hole in each hinge (not all the way through!) between the two bolts. When you reinstall the hood, line up the drill bit hole and insert the same bit size in both. Now you've placed a perfectly lined up hood!
56 F-100 hood hinge trouble hooler1 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 09-03-2016 09:57 AM
Hood hinges or springs ? bbf150 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-16-2015 09:53 PM
How to keep back of hood down on 54 abe 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 12-07-2014 10:46 PM
Hood spring hinge question SC'79 1973 - 1979 F-100 & Larger F-Series Trucks 15 12-13-2011 10:42 PM
53-56 Front sheet metal alignment procedure AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 02-12-2011 09:38 AM
Tags
1967, 1977, 1979, 79, adjust, f100, f150, f250, ford, hood, side, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
