351M Firing Order - Ford Truck Enthusiasts Forums
351M Firing Order
Old 10-23-2005, 10:59 AM
93redneck150's Avatar
93redneck150 93redneck150 is offline
93redneck150 is starting off with a positive reputation.
351M Firing Order
Does anyone know what the correct firind order is for a 1977 351M, the one in the haynes service manual is way different that the way my truck is wired and before i go changing the order on mine i just wanted to know what it was really supposed to be.
Thanks
Dave
Old 10-23-2005, 11:01 AM
EricJ EricJ is offline
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
15426378 firing order'
1234 is on passengers side, 5678 is drivers
Old 10-23-2005, 11:12 AM
Zod Zod is offline
Zod is starting off with a positive reputation.
No! 13726548
Old 10-23-2005, 12:49 PM
Quote:
Originally Posted by Zod
No! 13726548
OOPS, you are correct, not enough coffee this AM
Old 10-23-2005, 03:44 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Just so you know
FTE has a 335 engine series forum for questions like this.
Old 10-24-2005, 09:31 AM
firing order
Thanks for the help, we got it running good now, after looking at it again we noticed that the vacuum timing advance was disconnected, the choke was partially stuck on and the carb wasnt even tightened down on the intake all the way, but now it runs good.
Thanks
Dave
Aluminum Side Step Recommendations Please No More Raptor 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-09-2013 12:14 AM
96 302 Firing Order Decoder01 1987 - 1996 F150 & Larger F-Series Trucks 14 01-23-2011 10:56 PM
1-piece or 2-piece fuel pump eccentric? davelength Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 08-18-2009 09:45 PM
'98 Expy front license plate bracket Buzzcut Expedition & Navigator 5 04-13-2006 05:49 PM
How To Hot Wire? TUFFY 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-18-2003 01:06 PM
Tags
1977, 1978, 1979, 351, 351m, engine, f250, f350, fire, firing, ford, modified, order, ranchero, uo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
