tell the dif between 400 351m ?
10-21-2005, 05:07 PM
on
what is the easiest way to tell the difference?
10-22-2005, 01:19 AM
on
valvecover or do a stroke test. They is no super easy way that I know about. Its like a 360 and 390, you have to measure the stroke.
10-22-2005, 01:12 PM
on
what does the valve cover have to tell the diff?
the crank is getting ready to come out is there a casting number that can be used?
10-22-2005, 07:09 PM
In that case, measure the stroke from the underside.
4 =400 3.5=351
10-22-2005, 07:43 PM
1K is the crank casting # for a 351M. 5M, 5MA, 5MAB are casting #s for the 400.
10-22-2005, 09:36 PM
on
thanks thats what iwanted ti know where is the casting mark at?
thanks guys
10-23-2005, 02:08 AM
it's on the first counterweight of the crankshaft. 1K or 5M
10-23-2005, 04:32 PM
The valve cover often has a sticker with the engine size.
10-23-2005, 06:51 PM
on
cool i got a 400 crank thanks alot fellas
10-23-2005, 11:18 PM
did you drop the pan? after all these years any valvecover/sticker could be on there.
10-24-2005, 10:54 AM
on
no the crank is now in my garage (out) the motor is now striped to the bare block
thanks again guys
10-25-2005, 11:56 PM
unless someone changes valve covers on you... found out the hard way on that one...
