Cam position sensor
Old 10-23-2005, 08:03 AM
Ryyback's Avatar
Ryyback
Ryyback is offline
Talking Cam position sensor
Hey all,
I'm new here and have been reading around the site. My F150-1998 4,2 6cyl 90,000 KMS[55,000 MLS],has a 'check engine light' on. I had buddy hook it up,and it can back with 'cam position sensor'. Question would be is where is that on my particular engine,and could it be just a matter of needing new plugs and wires????
Thanks for any help in this matter
Ryyback
Old 10-23-2005, 08:38 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Old 10-23-2005, 08:42 AM
Ryyback's Avatar
Ryyback
Ryyback is offline
Ford truck
Thanks for the welcome,good to see a site dedicated to Ford Trucks and the like.
Ryyback
Old 10-23-2005, 11:27 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Are you having any symptoms other than the check engine light on? Most of the time when the cam position sensor is shot that's the only symptom.
I don't think I've replaced any cam position sensors on 4.2L engines but I have on other Fords. It is at the front of the engine, where the distributor would be if it had one. It's round, probably about 2 inches across and about 3/4" tall. It has 1 electrical connector and 2 screws holding it down. Once you have it removed check the "blades" underneath it for damage. You'll see what I mean when you're there.
Old 10-23-2005, 11:38 AM
Ryyback's Avatar
Ryyback
Ryyback is offline
Hey there,
Thanks for the reply.Yes other than the 'CEL' it did stall once and close on 1 or 2 other occasions.?????
Old 10-23-2005, 11:46 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
The ones that I've seen haven't caused stall but anything is possible.
Please let us know what you find with it.
Old 10-29-2005, 05:06 AM
Ryyback's Avatar
Ryyback
Ryyback is offline
Cam sensor
Hey Racer,
I got my F150 fixed on Thursday. The Cam Position Sensor was pooched. The magnet inside was busted off, luckely the shaft that goes round and round inside the sensor was not damaged.Th CPS controls the plugs,hence why it was stalling every so often. I also had to replace a pully and the belt, as they were in bad shape too. The pully was starting to sieze, and the belt after 90,000 klms or 60,000 miles was starting to show its age. So after $598 cdn I am good to go.As the old saying goes-fix now or pay more later. I could have been paying alot more for this problem to go away.LOL-TTYL
Old 10-29-2005, 08:17 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Good to hear that you got it fixed
Old 02-14-2009, 02:22 PM
krunchy1's Avatar
krunchy1
krunchy1 is offline
I have a 2000 F150 4.2L 2WD, and the Cam Position Sensor trigerd a check engine light. First, where can I find an Engine diagram to find where it is. I think I have located it, but its almost impossible to get to. HELP!!!!!
Old 02-15-2009, 05:47 AM
Ryyback's Avatar
Ryyback
Ryyback is offline
Do a quick 'Google' for a road map of your engine.
Yes they are in a bad place, so I bit the bullet and spent the $500 to let someone else do it. What took them a couple of hours would have taken us a week-
jrbubachmech98
2004 - 2008 F150
72
11-17-2022 01:13 PM
clodmore
3.0L V6
226
01-25-2019 07:01 PM
Jonathan Day
2004 - 2008 F150
10-03-2016 04:06 PM
thebikerbob
Modular V8 (4.6L, 5.4L)
07-13-2015 08:15 PM
68ragtop
3.8 & 4.2L V6
15
02-16-2006 06:07 AM
Quick Reply: Cam position sensor
