pics of true dual exhaust 92 f-150 4x4? - Ford Truck Enthusiasts Forums
Old 10-23-2005, 04:56 AM
RyanJake RyanJake is offline
RyanJake is starting off with a positive reputation.
Question pics of true dual exhaust 92 f-150 4x4?
I am looking to replace my exhaust with true dual, however as you all know I have a little problem with the front tank and transfer case on the driver side. i also need to put the two cats somewhere when the exaust is built. Does anyone have any pics of theirs or any suggestions on how to do this. I do already have shorty headers. Thanks Guys
Old 10-23-2005, 07:26 AM
93f250-44cepeks-olf-olf 93f250-44cepeks-olf-olf is offline
93f250-44cepeks-olf-olf is starting off with a positive reputation.
I don't have pics, but it pretty easy. Both pipes are leading into one cat on the factory setup. Cut off the cat, and install to cats parrallel to eachother. Your mufflers will have to be parrallel as well ( about 3" apart). From the muffler back you can adapt a cat back dual system or have it bent up at a muffler shop. I had mine bent up at mineke about 3 1/2 years ago. I'm a little dissapointed with how much rot there is on the tail pipes already.
Old 10-23-2005, 11:10 AM
moose94's Avatar
moose94 moose94 is offline
moose94 is new and has a neutral reputation at this point.
I have pictures in my gallery. Its headers, true duals, NO CATS!!!, and a pair of mufflers that aren't on there anymore. Hope it helps.
Old 10-23-2005, 02:40 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
Well, if you adapt long tube headers to your truck (which would mean dumping the EGR and whatnot) you could always run the Dynomax "true dual" setup that Summit and Jeg's sell.
Old 10-23-2005, 02:59 PM
RyanMiller's Avatar
RyanMiller RyanMiller is offline
RyanMiller is starting off with a positive reputation.
Mines a 86 but its bacicly the same, check out my gallery.
Old 10-23-2005, 10:13 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
This is just an idea. This is the system I am running, though I don't know for sure if it'll work with a 4x4 (transfer case). The exhaust dumps out the side, just before the rear tire.
Dual Exhaust on a 5.4 Garst250SD 1999 to 2016 Super Duty 9 01-13-2012 02:45 PM
true dual exhaust kits? BACKWOODS99 1999 to 2016 Super Duty 5 06-23-2011 04:52 PM
true dual vs. crossover? papajoemrt Exhaust Systems 23 11-13-2007 11:25 PM
True dual exhaust? 203008581 Modular V10 (6.8l) 22 02-13-2003 09:33 PM
true dual exhaust Pastmaster 1997 - 2003 F150 3 03-23-2000 11:33 AM
Tags
04, 1987, 1994, 302, dual, exhaust, f150, f250, setup, system, true
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
