2000 f150 v6 engine
2000 f150 v6 engine
I would like to know what do I have to do to remove the transmission from the engine? It is an automatic transmission and I do not know how to access the torque converter, or how to disconnect the engine from the transmission... can somebody help me please?? thanks a lot, Vand.
on
Hi vprado, and welcome to FTE! Please take a moment to check out the guidelines, they contain some important info you'll need when posting here:
https://www.ford-trucks.com/guidelines.html
I've moved your thread into the appropriate forum for you're vehicle, you should get more information to help you out here.
I haven't had the transmission out of a 4.2L truck in a while but I think there should be a cover on the bottom of the bellhousing that is held on by 2 bolts. Remove the cover to access the torque converter nuts. If that's not the case then you can probably access them through the starter hole once the starter is removed.
nuts
hi, there is a rubber blanking plate held in by a clip and is to be found on the flat face of the bell housing on the driver side, not the starter side. becarefull as the nuts are very shallow and easy to round-off.
there is a rubber bung at the bottom off the bell housing that the torque convertor drain plug can be accessed.
regards bokker.
regards bokker.
FUJINAMI1293
01-12-2017 07:10 AM
Hazelwoodgarage
01-08-2016 04:54 PM
wannab4wd
08-11-2001 07:32 PM
