Oil recomdations and cleaning rockers - Ford Truck Enthusiasts Forums
Old 10-22-2005, 04:07 PM
cbfomoco cbfomoco is offline
cbfomoco is starting off with a positive reputation.
Ok I did a search but really did not find anything. Any oil weight/ additaves i sould be putting in my motor?? any a desent cleaning oil? My motor is really not to dirty except on the rockers? anything i can use to clean these? I thought about motor flush but was told it would smoke if i used it?? So i would like recomdations on oil, and what i can use( eather intenal as a supplement or manual as in take covers off and clean) to clean my rockers with. I have taken the oil pan off and cleaned as well as intake and valley pan. thanks
Old 10-22-2005, 04:21 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
just use a good oil and filter. no need for flushes. use a diesel rated oil in the 15w40 grade like delo,delvac,mystik,rotella and you will be set.
Old 10-22-2005, 04:41 PM
OUt of coursity why the des oil? thanks
Old 10-22-2005, 05:13 PM
Homespun91's Avatar
Homespun91 Homespun91 is offline
Homespun91 is starting off with a positive reputation.
Because it still has zinc additives, which help lubricate high-pressure wear points like the cam-lifter interface. As virtually all new vehicles have roller cams, or cam followers, they don't require as much zinc. (Less combustion chamber deposits with the new zinc-less oil formulations).
If diesel spec oil isn't an option, you can also use GM's EOS as an oil additive, or Crane SuperLube, or even STP. Any additive that lists ZDDP will work. Also, racing oils generally have the zinc compounds, if you can get the correct viscosity, & can justify the extra $$$$. Me, I'm cheap.
FWIW, it's most critical to use this type of oil when breaking in a new engine, or new cam/lifters. You can get away without it on an existing engine that's well broken-in....but it don't hurt any.
Old 10-22-2005, 06:14 PM
cool, thanks
Old 10-22-2005, 08:21 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Regarding oil additive containing ZDDP. I made an inquiry over on the Oil and Lubrication forum. The guys over there recommend the Valvoline Synpower brand additive due to the amount of ZDDP it contains, 230 ppm. The additive labels may say that ZDDP is contained, but not the amount. For instance the SciTech additive is labelled as containing ZDDP, but it is only 20 ppm.
Old 10-22-2005, 08:59 PM
here it is
Elemental Analysis (ppm)
Copper: 1
Iron: 2
Chrome: 0
Nickel: 0
Titanium: 0
Silver: 0
Lead: 0
Tin: 2
Alum: 34
Silicon: 0
Sodium: 23
Potassium: 1
Moly: 2324
Boron: 1046
Barium: 0
Calcium: 1050
Magnesium: 968
Mangan: 0
Phosphorus: 1792
Zinc: 1740
divide by 33 to figure out the amount per oz.
coolant amd_038 6.0L Power Stroke Diesel 15 08-20-2011 09:03 PM
mouse proofing?? cbfomoco 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 11-30-2005 08:30 PM
Maganzine Articals cbfomoco Ford Inline Six, 200, 250, 4.9L / 300 12 10-26-2005 10:41 PM
water pump cbfomoco 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-18-2005 02:34 PM
recomendations for dana 80 rearend dual wheel parts gears&bearings for 2000 psd RogerFord1 1999 to 2016 Super Duty 1 02-25-2004 05:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
