94 Headlight disasembely
Originally Posted by ryrett
I just need to change the bulb, not the whole thing. How would this procedure be different?
In back of the headlight take ahold of the bulb receptacle and turn about a quarter of a turn and pull the bulb out.
Take ahold of the bulb and pull out.
Push bulb in not touching bulb with fingers (use paper towel).
Put socket back in.
Well I've read this post all these post at least 10 times. I've stared holes in the picture looking so long. I took the battery out, removed the tray and I have two horns behind the light assembly. I don't see any screws, or bolts back or donw there.All that I see are the screw ends pocking thrugh. The chrome frame feels like it's bolted on the bottom...I'm lost...I have a 93 F350 XLT. Ford said I had to remove the parking running lights first..blah blah..need some help..
and the holes are under those with the nuts to remove? I saw two bolts on the botton but nothing that points out that seems to hold the frame on...how do you remove the parking lights? The guy ar Ford seemed to say they had to come out first..I'm almost to the point of breaking mine and buying a replacement for $53.00
The parking lights just come out by twisting the socket. You can not see the nuts and I am not sure if you can feel them. You just have to stick a socket in the hole, unscrew the nut and hold it on the socket with your fingernail to keep from dropping them. It is even more fun putting it back in.
I know, now. I made this WAY too hard, when I finally figured out what the deal was, I was pretty humbled, and how easy it was to change the bulb.
It still isn't working correctly. It is a very dim compared to the other head light. I can get it to be as bright if I wiggle or mess with it, but then it gets dim again. So, being that it is a halogen light, I don't think it's the bulb, but rather the connection, so I am going to try spraying some contact cleaner in the sockets and put it back together.
Any ideas?
Any ideas?
believe me if I didn't have to replace the entire assembly I wouldn't be taken on this task ..my headlight assembly on one side overheated (before I bought it) and the back melted to the extent I can't screw in the bulb or plug.. I've owned Ford trucks for many years and know how to remove the bulbs...I've also remove plenty of headlight assemblies, this is my first for the F350 and It's almost impossible it seems
Any ideas?
Any ideas?
#28
Any ideas?
Any ideas?
#29
Well, this is an encouraging thread!
The headlights on my '95 F250 were ridiculously dim. So I installed high output bulbs this evening. That was the easy part.
The plastic highlight lenses look like crap though. Funny, because the clear corner ones look new. Maybe they are. In any case, I really want to remove the headlight lenses and clean/polish them. New lenses from an online discount supplier were priced at nearly $200 for a set!
So I'll be searching for the elusive 7/16" nuts with my extended socket, fingernail at the ready!
#30
harj1959, I went down to Schucks auto parts (part of the auto zone chain) and bought some plastic polish. The type of plastic is similar to what we use here in jets, (not as thick) but its lexan and you can polish out scratches. It takes some elbow grease but it's sure cheaper than new ones...I did buy a new on eBay since my was over headed and shot for 26.00 (new) but the hassle to get at it was a pain. Anyway buy this polish and set down and polish away...works great. Put away the socket and save the nail.
