Ranger...Rough idle when warm
I have a 95 ranger (4.0) that starts up fine when it is cold, but sometimes when I start it up after it is warm it idles very low and erratically to the point it often will quit. When this happen...maybe 40% of the warm start ups, I have to rev it up right away and then it straightens out. All other situations it always runs fine when cold and hot after the initial start up.
<O</O
I have changed the plugs. The fuel filter was changed about 40K miles ago. Any other suggestions would be appreciated.<O></O>
thanks,<O
Hartwa<O
<!-- / message -->
<O</O
thanks,<O
Hartwa<O
<!-- / message -->
If I had to venture a guess, I'd say you either have a fuel delivery problem, such as a bad fuel pressure regulator or check valve, or your ECT is messed up and not telling the computer that the engine is warm.
If you could do a fuel pressure check that might help the diagnosis, especially if you can get a reading while the problem is occuring.
Also, pull the vacuum hose off the the FPR when the problem occurs and see if there is any fuel in it.
