You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hay i have a 1996 F150 with a 95 "Air Dam" i need a fog light kit for it. The oem ford parts as you wood figure is $187.00 each. I need a kit with lights and wiring harness and switch. In other words i need a whole kit. Any ideas?
I ended up going to "Pep Boys" and geting a kit for $40.00 cam with every thing lights,wire,switch. I had to use "L Brackets" to hold the lights in the holes.
I will update my gallery soon.
I just pick up a air dam from parts train for one of my trucks. The question I have is when you installed your air dam did you have to drill any holes on the underside of the bumper. The one I got appears to have different holes than the regular stock air dam even though it is supposed to be for a Lightning. This air dam is going on a 96 extended cab Mark III conversion truck. Also what lights did you get from Pep Boys.
Thanks
Max
The air dam is directly connected to the front bumper on the GEN 1 L's, so you will need to drill some holes to fasten it properly.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
The body shop installed the air dam the fog light kit from pepboys is a "Rally" Kit Part#3104 almost a perfect fit looks dam good. I should have some picks up this weekend.
Thanks for the info on the air dam and lights. I figured that their would have to be some drilling involved for the air dam but had to ask. I'm leaving it black at this time. Love bug season down here in Florida will tear up the white paint bad. Only have to find a new rear bumper.
