I have a 1996 PSTD Crew Cab about 160,000 miles, it’s completely stock, except for a 6” lift and I just picked up a SuperChip for it and installed the High Performance Program in it. Other than that its stock. My problem just recently started, I will just be driving along normally and all off a sudden it will die for just a second, (split second). It’s like someone hooked up a kill switch and is turning it off while I’m driving for a sec. It doesn’t die to where I have to restart, but just too where it seems like it’s an (on off) hesitation. It doesn’t seem to happen as much since I installed the Superchip but it did do it again today only once. Last week it seemed to do it almost every time I went somewhere. One of the reasons I picked up the superchip was so I could see if any codes where popping up from this problem, and found nothing as far as codes. It is sure is an intermittent problem can’t seem to pin point. Seems like it could be electrical. Any Ideas?? THANKS!!!
cam position sensor.....
one can be had on ebay for around 60 bucks. its on the front of the motor.
this is a very common problem with psd's. good luck. ryan
nope but a million of people on here have. i swear someone no lie posts on this either in here or in the 99-03 forum about this once a day.
just be patient more will come along and post i am sure.
No, I will try installing a new one. its does seem like a good idea. I mean what do I have to loose, its not like it could get any worse. That link doesnt seem to work not going through.
yeah the link is good but it wont let you go there due to this sites rules about hotlinking. its an easy fix. 10mm wrench and a couple of minutes.
and yes it can get worse. your truck will end up completely dying and not restarting.
Trust him busa. i had the cps go out in my 95 250 and as far as the stealership told me it wasnt throwing codes. the only reason i ever got it fixed was this great website with the knowledgable people
ya, it's still misses sometimes but it did it even before I installed the superchip. I'm going to installl a new CPS this weekend and see what happends. I'll let you all know how it turns out. hopefully its a easy install. THANKS!! for all your input.
