Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2005, 10:39 PM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.
Glow Plug/gpr/hard Winter Start And White Smoke Thread
ok guys heres the deal. i got the go ahead from cookie about making a sticky thread on changing glow plugs, gpr, ohm readings, finding your block heater cord, white smoke and anything valuable you can add.
the reason i thought of this was last fall/ winter myself and a million others had problems with our trucks. so hopefully we can make this thread a one stop shop for all who require assistance. and also not see 100 threads a day about gp's.
removal of glow plugs(if there was autolites installed before you will probably have issues trying to remove them)
1. a deepwell very thin walled 10mm socket is almost a must for removal of glow plugs!!!!(if it is thick it will hit your rocker arm/ pushrod and get stuck)
2. a little medicine dropper to suck the oil out of the recessed area on top of the glow plug so it doesn't run into your cylinder when you pull the glow plug.
you will also need a torque wrench that goes as low as 14 ft lbs.
the way to get the passenger side valve cover off you gotta lift the firewall end up first then the front side of it to get it out. not to bad. that back bolt takes some work a shorty 13mm and a 3/8 in drive ratchet and a lot of ratcheting motions.
a few part numbers
glow plugs
(AutoZone) ZD-10 or ZD-11 (Beru plugs) about 9 bucks comes in oem ford package.
(Ford) F4TZ-12A342-A
(International) 1820697C2
i cant emphasize this enough. do not buy AUTOLITE GLOW PLUGS
Glow Plug Deactivation Kit (opens at 115 degrees coolant temp)
(International) 1831142C91
Glow Plug Relay
(Allied Electronics) 576-1078 (Stancor Heavy Duty 586-902)
(AutoZone) MR99
(Ford) F7TZ-12B533-CA (94-96 with pigtail)
(Ford) F81Z-12B533-AC (96-early 2000 w/o pigtail)
(International) 1807230C2
(International) 1826634C94
(Napa) GPR-109 <-----20 bucks at napa
Glow Plug Relay shunt; Required for GP monitor circuit; 97 CA
(Ford) F7TZ-12B533-B
GPR:
is located on passenger side of valley by the fuel filter housing. looks like a starter relay.
WHITE SMOKE:
unburnt fuel. if you have this on a cold start up you probably have 1 or more gp's not working.
BLOCK HEATER CORD:
orange cord that comes out of engine right above oil filter housing. follow it forward. it is probably in your bumper somewhere. if you see no orange cord you probably dont have one on your truck.
i am sure i missed lots of things . but that is where you come in. please dont repost something that is already here. i definitely need someone to post on ohm reading and the testing portion.
if you find in the process of changing out your glow plugs you have the following: burnt uvc wiring, burnt connector on gaskets, or external plug damage click here for part #'s, cost and what it looks like and cheapest place i found to order part from.
thanks in advance to all who contribute and good luck to all that take on this task.
also wouldn't be a bad idea if someone could dig up one of there old writeups that had a glowplug stuck. copy and paste the actual content into this post to avoid having to click on a whole bunch of links.
__________________
05 D-MAX WITH SOME GOODIES
  #2 (permalink)
Old 10-20-2005, 07:45 PM
RedStroker6's Avatar
RedStroker6 RedStroker6 is offline
RedStroker6 is starting off with a positive reputation.
dude, awesome idea. and props to the mod who decided to make it a sticky. good thinkin' ya'll!
__________________
Adam
95 f250 PSD ZF5. Twin 5" stacks, 5.6K, 6637, Kenwood Deck, 2 Kicker CVR 10's, Audiobahn amp, AutoMeter Pyro. ugly truck but my gal loves it
  #3 (permalink)
Old 10-20-2005, 11:25 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
What is an International Glow Plug Deactivation Kit? First I've heard of it.
I'm assuming from its description that it opens the GPR coil above 115 degrees F.
Got any more information on its use? Is it only OEM on Navistars?
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #4 (permalink)
Old 10-23-2005, 12:05 PM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE. cangim is gaining momentum as a positive member of FTE.
Checking Glow Plugs
Each valve cover has an electrical connection; each connector has 8 pins. The two outer pins on each side connect to the glowplugs under the cover. The center four pins connect to the injector coils. You'll need a multi meter that can measure ohms. Connect one lead (usually the balck one) to a good ground. Then probe each of the outer pins on the connector. Good glow plugs usually measure between .8 ohms to 1.5 ohms. Some may be outside of that, but won't stray too far. Bad plugs can measure anywhere above 20 ohms, for instance, when I replaced mine, I had three plugs that measured 800 ohms, two that where open or infinite resistance, and one that was around 600 ohms.
__________________
http://www.ford-trucks.com/user_gall...id=153297&.jpg
Wishin I was still camping somewhere....
-Mike
  #5 (permalink)
Old 10-24-2005, 08:46 PM
Lagerhead Lagerhead is offline
Lagerhead is starting off with a positive reputation.
Ive never had a hard start or a lot of white smoke during are brutle central florida winters
__________________
99.PSD,CC,SB,TS PERFORMANCE 4 PROGRAME CHIP,4"EXHAUST,STACKS, K&NOPEN ELEMENT FILTER
  #6 (permalink)
Old 10-25-2005, 10:29 AM
basstardo's Avatar
basstardo basstardo is offline
basstardo is starting off with a positive reputation.
Ok kiddies, I did everything this weekend, but I have a problem (other than finding an extra rocker arm under the passenger side valve cover between cylinders 1 and 3 ) The little black plug that goes onto the white wire that hooks up to the glow plug itself is worn out. Apparently it was up against a push rod for cylinder 3 for some time, and it has worn about 75% of the wire away. After changing everything out, I'm still seeing white smoke at startup, so I'm guessing that cylinder is causing the white smoke. So, would this be all I need?
__________________
Terry
2003 F-250, 6.0L PSD, 4x4, MagneFine PS Filter, Dieselsite coolant filter, Leer Cap
  #7 (permalink)
Old 10-25-2005, 04:08 PM
WuShock's Avatar
WuShock WuShock is offline
WuShock is starting off with a positive reputation.
I think you might emphasize 90% of glow plug related issure are GPR related and not so much GP related. I would hate to see all these guys go tearing into their trucks only to relaize its a 5 minute job to replace the GPR
__________________
2001 F350 CC DRW 4x4 7.3. Dyno 311 HP. 1/4 mi time 15.54. 1.9's 60ft. TS Performance 6 pos. Chip. Banks 4" Exhaust. Pillar Gauges. ATS Turbo Housing. ITP Boost Fooler. AFE stage 2 intake. Precision Industries TC http://www.putfile.com/kanman
  #8 (permalink)
Old 10-26-2005, 12:33 AM
onebadf250 onebadf250 is offline
onebadf250 is starting off with a positive reputation.
When you guys are talking about hard starts, are you referring to it not wanting to crank at all or the romp romp romp that mine made when I cranked it this morn in 38degree weather here in NWFL? I read a "Ford" fix that said to use a thinner CF grade oil...10W-30...I think is what it was.(Don't take my word on that though) But you guys have me wanting to check my GPR. If that is going bad will it throw a code that my programmer will pick up? I looked at the GPR replacement in my Chilton Manual and it doesn't look to bad to replace if need be. Any insight????
Thanks,
Rob
__________________
'00 PSD SuperCab 4x4, 4" Bullydog Exaust, S&B, 6" SuperLift, 35" BFG's, 3.73RE, Diablo Predator, Warn Hubs, WAR EAGLE!
  #9 (permalink)
Old 10-26-2005, 06:47 AM
1997F-350's Avatar
Quote:
Thanks,
Rob
if your truck wont start touch both big posts on gpr together with a screwdriver for about 15 seconds. then hop in truck and start. if it works its your gpr thats bad if not you got gp issues.
__________________
  #10 (permalink)
Old 10-26-2005, 10:58 AM
TimHixson TimHixson is offline
TimHixson is starting off with a positive reputation.
Can I use the GPR 109 on my 01 PSD truck?? Ford wants $101 for one!
  #11 (permalink)
Old 10-26-2005, 12:07 PM
wycowboy's Avatar
wycowboy wycowboy is offline
wycowboy is starting off with a positive reputation.
I belive yo can but not for suer, I have a 97 and obs truck and they wanted to sell me GPR110 for 90 or so but from all the checking I've done it seems that all the internals of the two GPR's are the same. and should work!J
__________________
97 F250 PSD, sc, 4x4 5sp, 3.55. 170K miles, 6637, dello dino oil bypass, SCTM, auto meter, Napa Coolant fliter. 203*t-stat,
  #12 (permalink)
Old 10-26-2005, 01:33 PM
Quote:
I got one at lunch (the 109). It looks the same, with two large studs and two smaller ones. I will put it on tonight and let you know how it goes.
Tim
  #13 (permalink)
Old 10-26-2005, 10:32 PM
cangim's Avatar
Thanks,
Rob
Yes the ROMP ROMP ROMP is a fine indication that something in not working, it would be accompanied by a fair to moderate amount of white smoke.
__________________
-Mike
  #14 (permalink)
Old 10-27-2005, 08:54 AM
Ok, I installed the gpr 109 last night, and have a couple of questions.
1. What does the bigger solinoid that is in front of the GPR do?
2. Do the glow plugs come on when starting a warm engine?
My engine had been off for maybe 10-15 minutes (while switching solinoids),
and it did not power the solinoid when I turned on the key.
I have not tried it again yet.
  #15 (permalink)
Old 10-27-2005, 09:45 PM
WuShock's Avatar
Quote:
When you got to Napa tell them you need a part # GRP-109. They are around $20. If you ask for one by year and model of truck youll pay closer to $60 or $70 for one.
I put a a Stancor 586-902 contactor in mine. I got it from Mouser.com for under $45. It is about 3 times the size of the stock GPR.
__________________
Tags
73 , 96 , bad , diesel , ford , glow , hard , newer , plug , plugs , problems , start , trucks , winter , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
