cold weather spark knock
Go through all your basic maintenance first - at 100k needs plugs, wires, clean MAF & TB, replace fuel filter, PCV Valve, air filter and clean fuel injectors. Check for vacuum leaks.
I have run into a lot of 4.6's that I have reprogrammed the PCM and that eliminated the spark knock but you have to get the maintenance done first if it hasnt been done yet.
Along with the tune ccoram is reccomending use SeaFoam in the engine to clear away the deposites in the engine. you can add it to the tank but best results happens when you run the engine remove the pcv valve stick the pcv hose into the sea foam can and suck up about 1/3 of the can, shut off the engien wait for about 30 min then restart. It will smoke like crazy (white) for about thirty min go for a drive until it clears up. You will see a vast improvement, At least I did on my 4.6.
Lance
Lance
i've heard of this Seafoam stuff....pretty easy to find?? also forgot to mention that it only happens once the engine is warmed to operating temp.....i cleaned the MAF about 18 mos ago....probly start there and do the "decarboning" as well.....thx....i assume the carbon buildup on the piston tops causes excess heat due to higher compression, thus the knock??
tbm3fan
23
08-02-2014 07:58 AM
Joe's Creations
39
05-02-2008 12:10 PM
1tilden
03-13-2006 05:36 PM
