You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 2002 Explorer with and airbag code 34 by counting light flashes. I have found somewhere that code 34 is driver side airbag low resistance or shorted. The cruze and horn still work. What now?
Ford says that the restraint system has a 5 year 50K mile warenty and that it would cover an air bag module, but not a sensor. If the airbag has low resistance or is shorted would this be covered?
From what I am reading the clock spring usually gives a high resistance reading... code 32.
Could be the clock spring or the airbag it self. I'm leaning more toward the airbag. If you take it to the stealership, they can put an airbag simulator in place of your driver's side airbag and see if that solves the problem.
You could unplug the air bag and then you would have hi resistance so your code should change, that is if the problem is in the bag.I wasn't aware you could count flashes on the air bag system. I use a AutoDiag scanner by DiagTek but they don't sell them anymore, but I have seen them on EBay
LFC or light flashing code 34 ( DTC B2292 ) is passenger seat pretensioner fault which may be caused by intermittent connection at either seat buckle.
Article 03-11-03
They have kits depending on build date and interior colour.
