water in fuel
sure ...
you have water in your filter housing.
to drain open top flip up motor cover, on the passenger side of the filter bowl you will see a yellow handle. this is a drain valve. this will drain quite a bit of fuel so you may wanna rig up a hose and catch can or not be on your driveway or somewhere it matters. there is a long metal tube that comes down on the front of motor pass side kinda up there you gotta look for it. that is where you will wanna put some hose on it to catch it if desired. if not drain away. you should do this periodically. good luck
like this
like this
