I have a 97 f450 with 100k on it.. It is only running on the right four cylinders..If i plug it in for a few hours I can get it to start but while running I can unplug both of the Left driver side plugs that goes to the injectors and glow plugs and there is no change..I have replaced both valve cover gaskets and all four of the wiring harness, new icp,new cps,two new batteries,changed oil,changed fuel filter...Now what maybe the computer or ipr...Thanks for any help...
I changed the IDM and now the truck runs a drives perfect..But when I first start it when it is still warm it surges up and down untill I hold the pedal at about 1500 rpms for 30 sec and when I let up it Idles perfect...What next..Thanks
Removed IPR,cleaned it,replaced O-rings,filed with oil and now it won't start...I have been working on it all day...I did notice that the sceen on the right of the fuel filter had alot of slimey stuff on it..I cleaned it and replace the o-ring on it also..
