Filling the Cowl Vents
I wouldn't, been gassed enough not having all of the clutch pedal/shifter boots intact.
I started thinking ducts on the side of the cowl with an up-draft cofiguratrion to limit moisture. Then I started thinking about flex duct from the firewall through the hood somewhere. Then I started thinking about water traps. Then I started thinking about vents with remote control 180* adjustable shutters. Then I stopped thinking so hard.
I need a personal smilie that has smoke coming from it's ears.
I've considered this too. In stock form, the air comes in the cowl, down the passenger side and into the passenger kick panel where the heater draws the air in. I've thought to fill the cowl vents, and use piping from the kick panel area behind the fender to the front radiator support for fresh air. Would get fresh air and would be unseen if run inside the top of the inner fender area. Just a thought.
Marty
Marty
I've been kicking this idea around 4 a little while now. I'm going 2 re-do my front clip to tilt 4ward, and was considering duct work from the grill, running along the inside top of the hood and mating up to a hole in the front of the cab just below the cowl. Similar to the way some big trucks draw air into their intakes...? What say you to that **** poor idea...?
Brad
Brad
BradsF1
28
11-29-2014 11:35 PM
Randy Jack
17
07-24-2005 11:50 AM
Matt Scassero
05-26-2004 06:18 PM
Matts68f100
04-21-2003 08:04 PM
