amsoil or elc coolants
any body running them?? ive been going back and forth between the cat elc, jd elc (which im almost sure is the same) and the amsoil coolant. anybody know of metal compatibilities with theese? or any other problems? ive gota coolant filter too. i just dont want to deal with the sca's and i gotta replcae my coolant housing its leaking and im gonna put a 203 in there while im in there.
AllyouPSDownersoutthere
The answer to your coolant additives is CAT EXTENDED LIFE COOLANT. This is a premixed coolant for all engines with cavitations problems. Just flush out other coolant. Takes approx 5 1/2 gals @ approx $6.00 per gal. All the info is under CATERPILLAR'S WEB SITE www.cat.com Check with any Heavy Equipment or Road Truck dealer, most carry. This coolant is good for 300,000 miles do not add water or additives.
i dont know what you mean i copied and pasted this right from his site. is there something i am missing here? i thought this was some good stuff i always hear of it being used over at tds.[img][/img][img]smokin.gif[/img]
All you PSD owners out there
this was copied right from his site.... what is wrong with it? i was planning on using it also but if there is something we should know about it please share. over at tds a lot of folks use it and i have never heard anything bad about it????????
zettawatt
Arizona Chapter
13
06-12-2013 11:09 PM
