water pump - Ford Truck Enthusiasts Forums
water pump
Old 10-18-2005, 10:13 AM
cbfomoco cbfomoco is offline
cbfomoco is starting off with a positive reputation.
water pump
any one have recomdations on a water pump? mine i think is done for. it is a 292 but has the heavy duty/ fan mount type on it. ( the fan has a big wide belt and adjust off the flange on the pump. and then the pulley runs the gen and wp and around the crank.) thanks
Old 10-18-2005, 03:33 PM
312 312 is offline
312 is starting off with a positive reputation.
you shouldnt have any trouble getting a truck pump.any reibuilt should be ok.i dont thing theres any difference in truck pumps no matter what fan set up.wherever you order will know.
Old 10-18-2005, 07:14 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Before I moved from the midwest, there was an auto supply place there, something like Carquest but dont remember, and you could turn your pump in, they would send it off, and a rebuilder would process it. You got your same pump back, like new.
You can get a 1954 pump at Concours, www.concoursparts.com , part number EAT 8501, 2004 price $119.00.
The part number for the 1954 unit is different than for 1956-64. Also, the 1956-64 truck pumps have a slightly larger diameter armature than those for autos, and the pulleys for the trucks have a larger center hole than the autos have.
Since you have a 292, it doesnt seem like the 1954 pump should be required as long as your fan/shroud/radiator configuration works out. In other words, like 312 said, you could run either a car or truck pump, 1956-64, with the corresponding pulley, with fan mounted on front of pump. If I am wrong here it shows my unfamiliarity with the 1954 motors. Belt would be narrow for the auto and wide for the truck. Auto pulley would be larger in diameter than truck, thus slowing water flow, which could be good or bad depending upon load sizes and whether or not rear has been regeared.
Old 10-22-2005, 08:07 PM
one last question does anyone make a new wp in the truck version? or look for n.o.s.?? I would like to try new before a rebuilt. thanks
Old 10-24-2005, 12:08 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
this pump is still rebuilt and the price is still cheap there is 2 listed one with 5/8'' shaft and one with 3/4'' here are the numbers Cardone 58235 Cardone 58234 simply copy and past the the number "only" at www.kragen.com they are 29.00 or 37.00
Tags
58235, pump, water, wp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
