Specs for 89 Ranger 2.3L - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-18-2005, 01:00 AM
LoneRanger89 LoneRanger89 is offline
LoneRanger89 is starting off with a positive reputation.
Thumbs up Specs for 89 Ranger 2.3L
Hi all, I had a new head put on my truck and now I have a tapping sound coming from the engine. I believe the valves need to be adjusted, I don't know the proper specs--do you? What's the proper torque for the valve cover? I also haven't been able to find info on lifters for my 4 banger, can they be adjusted? If anyone has this knowledge, I would greatly appreciate your help! Thanks
Old 10-18-2005, 06:59 PM
WallyRangerman WallyRangerman is offline
WallyRangerman is starting off with a positive reputation.
Are you sure it is lifter noise???
My '88 has a set of injectors that would out clack any of the lifters i heard as a kid!
have you ever heard an engine at start up that was low on oil?? clacks bad for a second or two and then smooths out! now thats lifter noise!
you can try the engine stethiscope or the stick trick to "look" for where the sound is coming from. put device to ear (carefull!) or jaw and touch other end to questionable noise maker item. then listen. injectors are somewhat isolated by an o-ring and are a little bit easier to "sound" out then the heads or the block.
Good Luck
WP
Old 10-18-2005, 09:10 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
My Ford manual shows no valve adjustment.
Valve covers are 62-97in-lb, NOT ft-lbs.
Old 10-18-2005, 10:11 PM
Thanks for the info Ken00, I will be able to check it out this weekend.
Old 10-18-2005, 10:12 PM
Thanks WallyRangerman, I will be checking it this weekend.
Rear drum brake adjustment gthbryce 1987 - 1996 F150 & Larger F-Series Trucks 25 08-14-2016 11:20 AM
5.0L valve adjustment Fordman2822 1987 - 1996 F150 & Larger F-Series Trucks 5 02-19-2011 06:05 AM
valve lash adjustment jdasilva644 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-16-2010 12:13 AM
valve cover bolt torque spec 302 efi oldblue89 1987 - 1996 F150 & Larger F-Series Trucks 1 07-24-2010 04:01 AM
Valve Lash Argess FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 12 09-26-2009 03:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
