4bbl Intake manifold - Ford Truck Enthusiasts Forums
Old 10-17-2005, 07:09 PM
Lobo 2's Avatar
Lobo 2 Lobo 2 is offline
Lobo 2 is starting off with a positive reputation.
Once again I need some advice from the experts here.
Iím finally getting ready to put my 292 back together. All the parts are back from the machine shop, the ecz-g heads are ready to go, etcÖ Then I realized Iíd forgotten the intake manifold. I cannot locate one of those ecz-b 4bbl intake to use a newer holley carb. Iíve given up... A new aluminum one will not fit my budget.
But on the other hand, Iíve located several ecz-a intakes, with the holley "teapot" bolt pattern.
If I make an adapter plate, would one of these work with my 292 and the holley? If so, does anybody know how to make one of those plates?
Thanks in advance.
Best regards,
Lucas (Lobo)
Old 10-19-2005, 05:06 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
to bad!!! theres a manifold on Ebay, but they won't ship to S. America...I think they made adapters at one time, possibaly you could find a used one......good luck
JIM
Old 10-19-2005, 05:17 PM
312 312 is offline
312 is starting off with a positive reputation.
you used to be able to buy these adapters.i dont know if you can still get them or not.you could make your own.
Old 10-19-2005, 06:38 PM
Lobo 2's Avatar
Thank you very much.
Well, if an adapter can be made, then I think I'll go ahead and get the older manifold.
As soon as I have some news of how everything worked out, I'll post here.
Thanks again!!
Best regards,
Lucas (Lobo)
Old 10-31-2005, 05:43 PM
Lobo 2's Avatar
Another question...
Hello again,
Iíve just got back from Texas and brought with me an early style intake and adapter.
The holley I have fits perfectly.
Now I have another question.
My ECZ-G heads are from a 1961 engine.
The intake is an ECB-9425-B, should be from a 1955 T-Bird, according to John Mummertís web site.
Iíve just remembered about those port size differences on the 57 and later heads. Will this manifold work with these heads that I have?
I was dumb enough to forget about these differencesÖ And carried a lot of weight for nothing if it doesnít fitÖ
Thank you very much once again,
Lucas (Lobo)
Old 10-31-2005, 06:34 PM
312 312 is offline
everything will fit.
How much CFM? hardlyrider 1957 - 1960 F100 & Larger F-Series Trucks 25 07-23-2016 10:21 AM
ISO ECZ 9425-B Intake Manifold kspragg 1957 - 1960 F100 & Larger F-Series Trucks 5 10-20-2015 09:08 PM
double heas gaskets 1960fordf350 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 07-11-2015 09:47 AM
ECZ-B Heads ? vze2c2gb Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 2 10-14-2014 07:12 PM
272 4bbl intake skotyg 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 05-28-2014 06:36 PM
Tags
223, 272292, 292, 312, 9425, adapter, bbl, ci, ecz, ecz9425b, fits, ford, intake, manifold, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
