My truck still stalls out coming to a stop
When I push the clutch in while slowing down to stop, I've had problems with my 86 302EFI stalling out. I ran a bottle of injector cleaner through it because I just changed the oil. I havn't even gone though the whole tank of gas yet, it already seems better, but still stalls out once in a while. Should I be using better gas or something?
An EGR sticking open will also do that. The EGR opens while cruising and is supposed to close when you let off the gas to stop. If it sticks open, it acts like a vacuum leak and stalls it out. You can just clean the carbon build up off rather than replacing it and it will act like new.
I would bet a coke that it is the EGR. -g-
Good Luck,
Lee
Good Luck,
Lee
The idle is set by the computer. But if you mess with the screw adjustment on the throttle cable, you can get it out of wack.
The first thing I would do is take the throttle body apart and clean it. Also take the IAC valve off the throttle body and clean it too. Make sure it moves freely.
Get it all back together, get it idling, and while idiling, unplug the IAC valve. If the engine suddenly comes to a stop, the throttle adjustment screw is too far back. If when you take the IAC plug off, the engine keeps running normal, then the throttle cable adjustment is too far open.
When you get it right, unplugging the IAC should make the engine slowly loose rpms and then die.
I took off the IAC yesterday and cleaned it out. It was free, but there was some soot in there, we'll see. I also pulled a couple plugs. They have about 10-15K on them, they were a little worn but looked pretty good. The wires, cap, and rotor are newer than that, probably 8-10k on those, but the rotor was carboned up on the end It was all premium napa stuff. I wire wheeled the rotor clean and put it back together. BTW I have an msd coil and spark box hooked to the TFI.
Make sure the passage ways are clear going to the IAC
Then do the pull the plug test on the IAC.
Have you pulled codes.
That is where you should be starting.
I've found out recently, that a bad distibutor and hall-effect (pick-up) can cause similar problem. That is a bit harder to detect though until they fail completely.
Also, check your base timing.
It has been my experience that a vaccum leak will cause a fast idle more than stalling.
It wouldn't hurt to replace the IAC if its carboned up real bad. If the truck was running to good, it could be the spark plugs are also carboned, and might need to be replaced. Pull a spark plug or two and check the condition of spark plugs, replace if necessary with some Motorcraft spark plugs. Some times it is necessary to remove the upper throttle body and clean thoroughly with throttle body cleaner, replace the upper throttle body gaskets.
Other items to replace are
- PCV valve,
- Cap and
- rotor,
- Gas filters,
- Air filter
- crankcase filter are sometime overlooked and need to be replaced,
- And good set of spark plug wires,
- Make sure the battery terminal are cleaned, it does make a difference on how an engine will run on these EEC IV computerized systems.
