400 Rough Idle - Ford Truck Enthusiasts Forums
400 Rough Idle
Old 10-16-2005, 11:55 PM
mljgauss mljgauss is offline
mljgauss is starting off with a positive reputation.
400 Rough Idle
Just installed a rebuilt 400 tough one from an auto parts store. Run motor for the first 30 minutes at 1500 rpm to lube the cam bearings well during break-in-in as recommended by tom's book. I think that number 4 exhaust value may be burnt. Engine misses and rough idle, very small but detectable (small tick like a value). Motor run very strong and mad oil pressure. Changed intake manifold gasket, which had no change. Will do a compression test at the end of the month.
Spec.
1978 F-250 Camper Special 400 CID <O</OHolly 600 Vacuum secondary
Weined Intake Mallory Unilite (LED) Pro Sidewinder wires Daynomax Headers<O</O
Old 10-17-2005, 07:37 PM
61ford 61ford is offline
61ford is starting off with a positive reputation.
try posting this in the 335 series forum right above this one it covers the 400
Old 10-17-2005, 10:21 PM
Thanks 61.
Ford 9-inch rear axle assembly -COMPLETE rockher_man Ford Truck Parts for Sale 0 09-12-2012 11:29 PM
MY 1956 F100 Custom Cab…running project rockher_man Vehicles for Sale 8 07-26-2012 05:28 PM
C4 & rear ratios & RPM's.... rockher_man Clutch, Transmission, Differential, Axle & Transfer Case 2 03-18-2011 10:08 PM
351W Issues when warm Rookie Shade Tree Mechanic CALINLEIR Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 04-28-2009 02:47 PM
To much Power? martin350 6.4L Power Stroke Diesel 38 02-15-2006 02:51 AM
Tags
400, cid, f250, idle, loping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
