Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 10-16-2005, 08:07 PM
hotrod48 hotrod48 is offline
Garage is empty, add now
hotrod48 is starting off with a positive reputation.
I Broke My Truck
I broke my truck racing Friday night (14th). Here is a link to the thread: http://www.ford-trucks.com/forums/sh....php?&t=420722 I don't feel like typing it again. Here is another link to the pics: http://www.ford-trucks.com/user_gall...&albumid=18456 So if anyone has any cheap or free 9 inch parts let me know.
hotrod48
  #2 (permalink)
Old 10-17-2005, 08:19 AM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Yikes. That is definately broken. Not bad for 50yr old truck parts. Good luck with finding a good used 9" rear. Keep us posted on what she runs when you get the new permanent rear installed.
p.s. if somethin's not breakin' then yer not pushing the skinny peddle hard enough.
__________________
-Ron
Daily Driver 1978 F150
  #3 (permalink)
Old 10-17-2005, 09:08 AM
I broke it pretty good. I thought the rear end held up good (Just chose a bad time to go). I have a 9 inch out of a 1958 F-100 with 4.11 gears (It needs rebuilt though). I would like to put a 3.89 gear in it, so I can keep about the same et because I plan to run a 14.0 index class next year.
Trust me, I am pushing that skinny peddle more than hard enough.
hotrod48
  #4 (permalink)
Old 11-07-2005, 09:42 PM
rogerf100's Avatar
rogerf100 rogerf100 is offline
rogerf100 is starting off with a positive reputation.
I have an open diff in 3.25 from a 1968 F100. It is just taking up space in my shed. Let me know if you can use it, free of charge.
__________________
RogerF100
True blue Ford fan
'55 F100 with '64 292 V8 3 deuces
'94 F150 Flareside
roger dot hughes64 at gmail dot com
  #5 (permalink)
Old 11-27-2005, 09:15 PM
Just a little update. After I put the original rear end back in, I found out my tranny was also broken. Today I finally dropped the tranny. It had a slight burnt smell to the fluid. The fluid was contaminated with little metallic particles, but cleaner than I thought it should be. I also found out my converter is trash (It rattles when I shake it, like the complete inside came loose). I will hopefully take it apart this week or weekend to see what else broke. I hope not much more.
hotrod48
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
