93 ranger blinker/trailer wire harness
Old 10-15-2005, 08:31 PM
mousejam515's Avatar
mousejam515
mousejam515 is offline
I went to auto zone and bought one of them plug in things for the back. when i pluged it into my trailer it worked fine. But after hitting the breaks a fiew times my abs light came on and my blinkers stoped working. so i checked the fuse. put a new one in and it was fine. then it did the same thing. so i put in a 20 amp fuse and it blew too. is the problem that the trailer is pulling to much power and blowing my fuse or is it something else? how can i fix this problem? i dont have a manual so idk what size fuse is actualy supost to be in there or how big i can go.
thanks
james
Old 10-15-2005, 09:48 PM
Hank85713's Avatar
Hank85713
Hank85713 is offline
sounds like you may have a short in the trailer hookup. If they work without the trailer and then blow the fuse when it is hooked up I would start checking either the connector or for a short in the wiring system. One time I put a 4 wire round recepticle in and when I used it the first time it blew the fused link on the battery. Turns out that there was a piece of one of the wires touching the recepticle. if yours is a flat 4 pin I would check all splices on the trailer and where ever you spliced into the truck. Just a thought.
Old 10-16-2005, 05:42 AM
jimw411's Avatar
jimw411
jimw411 is offline
It could also be a short in the wiring on the trailer.
Dutter 2
12-14-2014 10:26 AM
82f3504x4
04-17-2008 02:54 PM
rush2112
11-30-2006 05:49 PM
kidzstang
1997 - 2003 F150
05-20-2004 09:01 PM
engine9
1999 to 2016 Super Duty
11-24-2003 01:05 PM
Quick Reply: 93 ranger blinker/trailer wire harness
