Difference between 'van' and 'wagon'? - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 10-15-2005, 06:28 PM
SearchingBearCub SearchingBearCub is offline
SearchingBearCub is starting off with a positive reputation.
Just out of curiosity, I wanted to see if the '87 Star I was considering purchasing would get better or worse mileage compared to my expired '93.
Upon visiting www.fueleconomy.gov, I was confronted by two choices, both slightly different.
1987 Ford Aerostar Van - 18/24 (21 Comb.)
1987 Ford Aerostar Wagon - 17/22 (19 Comb.)
I don't see any obvious differences, so I put it to the knowledgeable people here - Which is which?
Also, a similar conundrum on www.kbb.com - When I went to look up the value of the van, I got 3 choices after picking "1987 Ford Aerostar - Private Party Value":
Cargo Minivan
Window Minivan
Minivan
Again, which is which?
Old 10-15-2005, 07:14 PM
xuzme720's Avatar
xuzme720 xuzme720 is offline
xuzme720 is starting off with a positive reputation.
as far as I know, there was no aero wagon. it might be one of those automated responses that sometimes make no sense. just a guess....
as far as the cargo, window and just plain minivan....
cargo has the solid sides, no windows.
window is just that. an aero with the side windows in the cargo area.
plain minivan....a guess here....maybe just another window aero. it might be a different rear door style, e.g. doors instead of a liftgate maybe. like I said a guess. maybe if you have the vin#, we can give more info.
Old 10-16-2005, 12:34 AM
93nighthawk's Avatar
93nighthawk 93nighthawk is offline
93nighthawk is starting off with a positive reputation.
Not a clue on this one, but I sure would like to know.
I am thinking that the millage dif between the two is for the Cargo one (first one listed, no rear seats or interior trim. Less weight = more mpg) where the second (wagon) has the trim and two more rows of seats. And man these seats are REALLY HEAVY, but comfortable.
Old 10-16-2005, 01:22 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
Ford always has had high quality seats. Loved the seats in a '78 Ford LTD, plush velour soft comfortable yet good bottom and back support for long hours behind the wheel. the Ford PU's I've had came from the factory with seats that one could take at logging road with speed and not bounce thru the roof or get spine compression. even the infamous death trap door falling off Pintos had great seats.
2 hours in one of the wife's Honda's and I'm ready for a chiropractor and hemmoroid surgeon.
by the way, the Pinto is where our auto trannys originated, the old French designed and built C3 + an overdrive and torque converter lockup, wha-la an A4LD. 70 hp rated tranny turned into something that had to handle twice the hp and 50% more weight.
Old 10-16-2005, 01:49 AM
Quote:
Back in late 2002, I bought a '96 Windstar from a BHPH. Had the most comfortable seats EVER! Who needs power adjustable seats - Just give me those seats again! Must've been 4-6 inches of foam for the butt, and almost as much for the back, plus great support.
Then again, the passenger seat in my '93 Aero was almost as comfy. The driver's seat, other than having wear on that same old entry/exit spot, must have had a broken spring, since I always felt like I was leaning to the left when I was driving it. Slightly annoying on long drives, lol.
As I understand it, pre-'92 Aerostars had the short back front seats. Are they just as comfy as the later Aerostar's seats? If not, is there a way that I can swap the front seats out of a '92 or newer Aero into this '87 I am considering?
Thanks...
Old 10-16-2005, 05:06 AM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is online now
xlt4wd90 is gaining momentum as a positive member of FTE.
I like the seats that came in my 87 Mustang; pretty comfortable, it not a little wide (need more side support) for spirited corner carving.
My 90 Aero has "captain's" chairs in front (arm rests on the inside). For some reason, they just don't seem to support me very well. If I'm driving in it for about an hour or so, I will usually slide down to the point where half my back ends up on the lower cushion. WHen I catch myself, I would have to struggle to scoot back up to my original, upright position. The lower cushion has a much flatter angle than that of my Mustang, which angles up a little, and has an adjustable leg support. I guess the Mustang's seat is really like a bucket, where once my butt is planted into the lowest part, it's hard for it to slide up, even with the weight of my torso pushing down on it. Whereas the Aero's seat is more flat, and unless I'm literally glued to it, I will be sliding down. But I am impressed that the fabric has stayed intact through all these years.
As long as you don't overload it, it should work. But I've heard too many stories, some from this forum, of the A4LD getting damaged if you sneezed at the wrong time.
100 MPG Excursion. Is this possible? fordcountry Excursion - King of SUVs 242 01-07-2017 12:13 AM
Some Skinny On O2 Sensors pawpaw Ranger & B-Series 5 03-15-2015 05:02 PM
Anyone Using Vegetable Oil in a 6.0 ??? Fieldday 6.0L Power Stroke Diesel 34 10-21-2014 04:12 PM
New FX8 Black Widow Blackstock Ontario Chapter 18 02-14-2008 12:17 PM
3 door ford truck tomoto 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 03-04-2007 12:05 PM
Tags
a4ld, aerostar, awd, contrast, diffence, difference, differences, diffewrence, ford, pinto, van, versus, vs, wagon, whats, windstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
