Can you use a Ford 460 164T Flywheel with a 428 Crank???
Old 10-14-2005, 10:16 AM
Ford428CJ's Avatar
Ford428CJ
Ford428CJ is offline
I would love to have an SFI approved Flywheel for my 428! I thought that I would throw that out there. The 460 is a hell of a lot cheaper then the 428 SFI stuff.
Here is the link to it:
http://fastengineparts.com/products_view.php?id=884
Old 10-14-2005, 10:55 AM
fordeverpower's Avatar
fordeverpower
fordeverpower is offline
I don't see why not, as long as you balance it. I don't know much about bolt patterns on the crank flanges though. I assume that they are the same.
Old 10-14-2005, 11:38 AM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
The 428's are all externally balanced with the flywheel. So you will for sure have to get the two balanced as an assembly, it it will bolt up. I have no idea if it will bolt up though.
Old 10-14-2005, 11:51 AM
Ford428CJ's Avatar
Ford428CJ
Bear,
I'm about ready to do a Balance job on my 428. But I will have to do a change up on my Flexplate. I have a new Pioneer but it isn't SFI Approved! I hate to say this but I dont want to spend $400!
Old 10-14-2005, 01:16 PM
Bear 45/70's Avatar
Bear 45/70
I always used the Ford stock flexplates for my CJ's, even in my auto race car. Did break it once, but that was 4 year of street and strip use and by then the motor was no longer stock (406 tri-power and headers and an aftermarket Crane cam). Of course the 4.30 rearend didn't lessen the abuse either.
73 ford guy
05-31-2014 02:56 AM
John with beastly 302
11-26-2007 09:08 PM
67 428 Fairlane Ranchero
01-12-2003 07:16 AM
astamp78
02-02-2002 10:02 AM
Quick Reply: Can you use a Ford 460 164T Flywheel with a 428 Crank???
