Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-13-2005, 10:51 PM
RedStroker6's Avatar
RedStroker6 is starting off with a positive reputation.
squealing clutch...
well, headin out to a movie tongiht with my sister, i noticed that my clutch is squealing....it sounds like a spinning sort of squealing. only happens when the pedel is up. when i push the pedel down, it goes away. it squeals when in or out of gear with the pedel up. the clutch is about a year and 3-4 months old (go figure, out of warrenty form the shop), and as far as i know, it is a single mass flywheel. any ideas? i'm gonna head out now to check the fluids and the like....
__________________
Adam
95 f250 PSD ZF5. Twin 5" stacks, 5.6K, 6637, Kenwood Deck, 2 Kicker CVR 10's, Audiobahn amp, AutoMeter Pyro. ugly truck but my gal loves it
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-13-2005, 11:12 PM
Kwikkordead's Avatar
Daddy what's a sparkplug?
Kwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud of
You sure it's not an input shaft bearing going south in the transmission? What makes me ask is the noise shows up when your foot is off the pedal and the clutch is engaged and spinning the input shaft. Oil level ok in the tranny?
Suggest getting some work clothes on and rolling under the truck, pinpointing the source of the noise. That information would be most helpful in diagnosis.
__________________
Dan
Our greatest priviledge is to enjoy God's Presence
  #3 (permalink)
Old 10-13-2005, 11:14 PM
Kwik, i just got out from under there, and the rear portion of the tranny is wet with fluid. not soaked, but wet indeed. it sprayed onto the exhaust pipe and baked it on. i'll have pics up in a few...btw, there was a larger amount of fluid looks like where the driveshaft meets up with the tranny
__________________
Adam
  #4 (permalink)
Old 10-13-2005, 11:17 PM
Quote:
Not a good sign. Check your transmission level, it should be level with the bottom of the fill hole.
__________________
Dan
  #5 (permalink)
Old 10-13-2005, 11:18 PM
Also check your transfer case, it's completly separate from the transmission, even though it's bolted right up to it.
__________________
Dan
  #6 (permalink)
Old 10-13-2005, 11:23 PM
where is the fill plug? sorry, i've never done work on it. heres some pics....
http://community.webshots.com/album/476235392OYWCtk
oh, it a 2x4, no worrys about a transfer case.
__________________
Adam
  #7 (permalink)
Old 10-13-2005, 11:36 PM
I tried to find a picture to post, but don't have one. It should be on the side of the transmission a few inches from the bottom of the case. On my six speed it's on the driver's side.
Those pics give me cause for concern for the oil level of the transmission. If you get it low enough, the bearings, gears, etc are forced to run dry and then it goes toes up.
__________________
Dan
  #8 (permalink)
Old 10-13-2005, 11:39 PM
i'll go have a look at the oil level. yeah, i too saw all the fluid down there and my heart sank. i hope it all started today...but again, i have put 80-90 miles on it since 7 this morning....but didn't notice anyhting different till this evening.
__________________
Adam
  #9 (permalink)
Old 10-13-2005, 11:41 PM
Good luck friend.
__________________
Dan
  #10 (permalink)
Old 10-13-2005, 11:58 PM
well, a bit of good news....the fluid level is fine. right up at the fill hole. had a hell of a time getting it open though. about bust somethin (in myself) tryin to get it to turn. the fluid was a sorta murkey green color.
so, knowing theres fluid around the back of the tranny, would an input shaft bearing have anyhting to di with it? i'm dumb when it comes to tranny's. i told myself i wanted to learn more about them so i could work on it next time something happened...is there a bearing in the back that could be going as well perhaps? and letting fluid by? is there an easy way to check any of these minus dropping the tranny...
on edit, it still shifts fine, and feels ok to run, it just squeals. the pedel feels a little funny (but that could just be a heightened level of awareness at this point).
__________________
Adam
  #11 (permalink)
Old 10-14-2005, 12:01 AM
fordfury469's Avatar
fordfury469 is gaining momentum as a positive member of FTE.
might check the throw out bearing. hopefully it something cheap which nothing ever is.
__________________
i cant think of anything so here it is.
  #12 (permalink)
Old 10-14-2005, 08:57 AM
Good news on the oil level. I would get that 90 weight out of there and put ATF back in according to specs. It's too thick. An alternative lube, and the one that I use, is Redline MTL.
Does the squeal go away if you touch the clutch pedal, but not depress it?
Also does the tone of the squeal change if you put it in gear, and idle along in first or second?
__________________
Dan
  #13 (permalink)
Old 10-14-2005, 12:04 PM
barebackjake's Avatar
barebackjake is starting off with a positive reputation.
i was gonna say the t/o bearing. definatley get that gear oil out of there and get atf in there i run amsoil synthetic but the redline is good stuff too it just needs to be full synthetic atf
__________________
97 F250HD 4x4 supercab 5sp 270k mi
4 link on air front and rear
2000 F350 CC 4x4 (wifes)
RIP CHRIS. 03/09/05
  #14 (permalink)
Old 10-14-2005, 07:12 PM
i'll give your suggestion a try tonight Kwik, and when i get a chance, throw some better fluid in there. i'm sure it could use a change anyhow. any idea on how much goes in there?
__________________
Adam
  #15 (permalink)
Old 10-14-2005, 07:19 PM
I have no idea, but your owner's manual should list it somewhere.
Good luck.
__________________
Dan
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
