292 Y Block - Ford Truck Enthusiasts Forums
292 Y Block
Old 10-13-2005, 11:48 AM
lilkenny lilkenny is offline
lilkenny is starting off with a positive reputation.
Question 292 Y Block
Hi this is Ken.I have an old 292 Y Block Ford motor with the Forged Crank,Rods and pistons..It's in decent condition..I was wanting to know if they are worth rebuilding ?? The crank ,rods are in perfect condition..The bearings look like new..There was some water damage in a couple of the cylenders...I could probably hone the cylenders out enough to re ring it..Is it worth my time and money to fix ?? Any information will be greatly appreciated.......Thanks.....
Old 10-13-2005, 12:44 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Hello & Welcome to the site!
This forum is for introducing yourself
Here is a direct link to the Y block forum.
http://www.ford-trucks.com/forums/fo...play.php?&f=56
Enjoy the site....It's huge !
Old 10-13-2005, 08:00 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Hi and welcome to FTE! Be sure to read this to help you around this site: http://www.ford-trucks.com/forums/sh...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
Thread moved to Y-Block forum.
See ya on the boards!
-Matt
Old 10-13-2005, 08:47 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
lilKenny, also welcome to the site.
If you look around on this forum you will see that we like Y's! If you rebuild the 292, what would you put it into? That could help with the "is it worth it" question. The Y-blocks now have more aftermarket parts than ever before, but still not nearly as many some of the other motors.
How did you determine you have a forged crank? Have you checked out www.ford-y-block.com to ID the year of the motor?
Mike
Old 10-14-2005, 08:30 AM
Thanks I appreciate the help...I have put it up for sale Here under 1964 292 Ford Y Block.. Forged Crank , Rods and Pistons...Thanks again......Ken....
Old 10-15-2005, 07:19 AM
f700's Avatar
f700 f700 is offline
f700 is starting off with a positive reputation.
welcome
hi and welcome yes the 292 is worth keeping
Old 10-15-2005, 10:39 AM
Hi..Thanks for the info...I have posted it for sale here on this web site...Thanks again.......Ken.....
Old 10-15-2005, 10:53 AM
Talking 1966 Ford 1/2 ton I Beam Front Suspension
Hi..Im looking for the Front left side of the 1965 / 66 Ford twin I beam suspension..The actual I beam..I'm restoring a 66 ford 1/2 ton pickup and the front suspension is bent from a kid hitting the ditch with it...Any information would be greatly appreciated....Thanks for your time...Ken....
Old 10-15-2005, 11:46 AM
46yblock's Avatar
You would have better luck posting what you need over on the 61-66 forum.
Mike
Tags
292, block, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
