in regards to train horns air leak
hey guys,
reason i am posting this is because i cant find where the air leak is.... i have my train horns connected as follows: compressor and tank mounted to 1/4 copper line into eletric selenoid valve to train horns...
I charge my compressor everyday and only lasts turned off 5 mins...seems like the air is getting out and everything is new!
well if you guys have any idea let me know.....am going crazzy hehehe
ok thanks,
Deltasoft
ok thanks,
Deltasoft
How bad does it leak? the air supply on the trucks at my work wont hold air after it has sit for a short time, and this is kinda normal for them. Does it build up air and hold it when the truck is running and power is supplied to the selenoid?, if so build up enough pressure and then turn truck off and get around the system and listen for leak, usaully it will lead ya to the source.
thanks a lot guys, well i will go with billy's idea to user soap and water solution and spray.....i have checked my whole entire truck for any leak and havent found it....i dont hear any gap of air... at first it was in the fittings which i fixed it up by putting them tighter but now no sound and it doesnt even last an hr charged.........so i will try solution....i'll let u know what happened guys.......in the meantime if any of you have other ideas or things that have happened to you in regards to this that i can check for let me know.....thank you very much
diesel-fitter-bum01
22
10-26-2010 04:49 PM
