main and rod bearing wear - low oil press. + - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 10-12-2005, 02:33 PM
madclone's Avatar
madclone madclone is offline
madclone is starting off with a positive reputation.
Maybe a week ago or so I wrote 'bout my problem - low oil pressure in 2.9 EFI. It did not go higher than 2.5 atm, when it should be somewhere between 3 & 4 ATM at 2000 RPM. Anyway, I opened the oil pan and took off the covers from main and rod bearings. Initially I was aimed to change MAIN bearings, but was very surprised to see, that they look OK - the surface is matt "alluminum" color, no scratches or evident surface defects. When I opened rod bearing covers and took a glance at the bearings - WOW! They're dead. Lots of scratches, the surface has "copper" color in some spots. Now I try to figure out how could that happen. As far as I understand main bearings are more likely to wear off. What do you guys think? Maybe previous owner already swapped main bearings? (unfortunately I can't contact him)
Another question is: do rod bearings affect oil pressure drastically? If I swap only them, will this significantly increase oil pressure?
I rely on your clever advise, Comrades
PS Forgive my English - I'm from Russia
Old 10-12-2005, 09:15 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
From what I've read the cam bearings and a clogged oil pump screen are the most common causes of low oil pressure in the 2.9.
Old 10-15-2005, 11:47 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
for what they cost I would replace the mains too, and you might find that the upper shell has more wear on it than the one you can see just by removing the main caps but Ken is right the cam bearings are also a major wear spot in these engines, and probably need replaced too which pretty much requires removing the engine. good news is you can do a ring, and bearing job on it for under $150 in parts if the cylinders aren't worn too bad and basically have a new bottom end.
Old 10-15-2005, 02:47 PM
ken1mod ken1mod is offline
ken1mod is starting off with a positive reputation.
Hi
I am a transplant from the aerostar forum. Last month I changed main and rod bearings on my 4.0 liter, 1991 'star. 182000 miles and box of rox noisy but good running.
Mains were perfect, like they were installed yesterday, maybe this morning. Rod beatings were worn through3 layers of metal. replaced them and returned mains. Interesting experience, check out my main and rod bearing post on the aerostar site. engine still has original noise, I believe it is piston related.
Ken
Old 10-15-2005, 02:50 PM
Sorry, I should add that main bearings lead a much easier life than rod bearings. they are larger and oiled continuously, not just in spritzes as the oil holes line up. they also don't have the centrifugal loads that rod beaings have and rod bearings are smaller. Mains last much longer than rod bearings.
Ken
Old 10-17-2005, 01:20 AM
madclone's Avatar
2 monsterbaby
my engine is half-removed it holds only to wire harness, fuel and AC lines. To get to the cranckshaft I had to lift it up 20 cm. To get to the camshaft I have to take the front cover off, right? And then pull it out of the bore? Can I get the camshaft out without taking off cylinder heads and valve rods/lifters?
2 ken1mod
comrade, please give me a link on your toipc, if possible. I'm not sure I can find it
Old 10-17-2005, 01:27 AM
To get the cam out you have to remove the intake, rockers, pushrods, and lifters. as well as the timing cover, and timing chain. Then to replace teh cam bearings takes a special bearing driver made for the application so your probably gonna have to take the block to the machine shop.
question about replacing main bearings PapaBearYuma 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-12-2016 11:42 AM
1973 F-500 Engine Questions 1988 Ford Inline Six, 200, 250, 4.9L / 300 13 06-25-2016 09:33 AM
First time engine building, scoring on connecting rod bearing? frdf250 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 04-14-2016 08:58 AM
1973 Low Oil Pressure pickenspolitics 1973 - 1979 F-100 & Larger F-Series Trucks 18 08-10-2013 08:01 PM
replacing rod/main bearings/front seal/rear main, any help/suggestions welcome v8only 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 10 05-03-2007 05:18 AM
Tags
2006, 460, bearing, cost, engine, explorer, ford, hole, line, low, main, oil, pressure, replace, rod, wear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
