Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-11-2005, 11:45 PM
kennedyford's Avatar
kennedyford kennedyford is offline
Garage is empty, add now
kennedyford is starting off with a positive reputation.
Smile Making bio this week in Arizona
Just bought the raw chemicals to start makin my own. 50.12 lb of sodium hydroxide known as lye = $27 and change and the methanol was $211 and change for 54 gallons but im starting with small more expensive quantities. So the free oil and these numbers equals what, 54 methanol makes about 540 gallons of bio and the lye will last me anywhere between 800 to 900 gallons by using i think a little over 6 oz per 100 gall..anyone else out here in AZ?
  #2 (permalink)
Old 10-12-2005, 08:17 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Talking Numbers??
Quote:
Your numbers are a little off. I've been making biodiesel for almost 2 years, and it takes 5 gal of methanol, and 2 POUNDS of lye per 25 gal of waste oil. FABMANDELUX.
  #3 (permalink)
Old 10-13-2005, 09:21 AM
Red face How clean is your waste oil
Quote:
A young apprentice I am. How clean is your wasteoil before you start? Can you send pics of your system so that I may observe your magnificent contraption? I went and purchased plastic barrels and I have quite a number of 55 metal barrels also. I went through and read all I could , of course a small test batch is in order. Im always interested in talking to the real deal instead of a paper printout. I also have someone coming from back east that can bring me e85 which is 85 percent ethanol and 15 of gasoline. I should be able to use this as a cheap alternative to the methanol. Do you have a recovery system to reconstitute the methanol out of your glycerin and reuse it? I got lots of questions...thanks for you imput. I need all the help I can get..Troy
  #4 (permalink)
Old 10-13-2005, 09:47 AM
1935 Ford pickup
Talking
Using e-85 will not work. When using ethanol it must be 100 percent, anything less will cause an incomplete reaction. Most commercial ethanol is at best 98 percent, and you cannot remove the remaining 2 percent by distilation, it must be removed by use of a molelecular seive. Yes i do have a "still" to recover the methanol from glycerol. I recover 25 percent of the origonal 5 gal input. I do not use an "appleseed" processer, but one of my own design. I posted pictures of my "setup" in the galleries section here. Any other questions? Always willing to help, just ask. FABMANDELUX.
  #5 (permalink)
Old 10-13-2005, 10:59 AM
ok, ill see if i can find your gallery later today. Thanks ...what type of vehicle are you running it in?
  #6 (permalink)
Old 10-13-2005, 08:21 PM
1935 Ford pickup
Talking
1996 ford F250 4x4,1991 dodge 3/4t 4x4,1981 vw Pu, 2 D-6 cats, Ford 9000 tractor, International wheel tractor, 2 International 6 cyl irigation pumps,Yanmar 18 hp pump, 38ft sailboat, 50ft powerboat, shop heat, home heat. I am now building a new heating system that will use the glycerol waste from my processer to heat the shop & house from a central location between the two. If you go to the archives and look up my previous posts you can get a better understanding of my system. FABMANDELUX.
  #7 (permalink)
Old 10-14-2005, 12:18 AM
Are you going to use the glycerin dried or wet with the methanol in it?
  #8 (permalink)
Old 10-14-2005, 08:54 AM
1935 Ford pickup
Talking
I ALWAYS recover the methanol first. That's how I keep my price per gal as low as possable. FABMANDELUX.
  #9 (permalink)
Old 10-14-2005, 06:12 PM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.1997F-350 is gaining momentum as a positive member of FTE.
do you mind sharing your price per gallon? thanks ryan
__________________
wanted: 97 350 XLT 4x4 REG CAB 5SP with less than 120k. C5,C9 OR 35,39 Does not matter. little to no mods done prefered. willing to pay premium$$$hoping to build another monster. doing the injectors myself this time with my OWN kit....no plain white trucks.NO CALI TRUCKS EITHER
  #10 (permalink)
Old 10-14-2005, 11:40 PM
1935 Ford pickup
Talking
Quote:
30 cents per gallon.
  #11 (permalink)
Old 10-15-2005, 12:17 AM
Smile
I looked at your photo gallary on that. It looks complicated. You still didnt answer on how clean your oil is before you start the process. Im looking at filtering through salt to seperate the water and other filter bags and pumps before starting. How do you get 30 cents a gallon. Mind sharing the math? Thank you once again Jedi master.
  #12 (permalink)
Old 10-15-2005, 09:08 AM
1935 Ford pickup
Talking
It's a lot less complicated than an "appleseed" processer! One of the major problem's with an "appleseed" is precleaning the oil before you can put it in the processer. With my system ALL the oil including "chunks" goes into my open top heater-cleaner. After it is heated to 150 deg I open the valve and the oil slides down the punch-plate trough where the "chunks" slide off the end, and the cleaned oil drop's into the mixing barrels. No pumps required! I used an "appleseed" first and thought "there has to be a better way" I've found that stiring the oil is much faster and a lot less hassel than pumping. I can do a 25 gal batch every 30 min so doing 400 gal in 8 hrs is no problem!
As to cost; cost
25 gal oil $0
5 gal methanol $6.90
2 lbs lye $.90
total cost $7.80
Less recovered meth - $1.72
total finished cost $6.08
25gal biodiesel / $6.08= 24 cents per gal [ i added 6 cents per gal for elect and misc costs
Also, after the oil is heated, 99.9 percent of any water drops out and settles to the bottom of my "heater-cleaner", And unlike the "appleseed" you can SEE the oil when it comes out and i catch any water in a waste barrel before I dump it into the mixing barrels. FABMANDELUX.
  #13 (permalink)
Old 10-15-2005, 02:21 PM
1997F-350's Avatar
that makes me sick........ it looks like its time to start doing a lot of reading. man thanks for sharing that is all the motivation in the world right there to start doing this asap.
__________________
  #14 (permalink)
Old 10-15-2005, 02:22 PM
cost
Well my 50.12lb of lye cost 27 and change. I wish I could have got the methenol cheaper though. Its a little over 8 bucks a gallon for five and a little over 3 if I buy 55 gallons at a time. Interesting why its more expensive in Arizona.
  #15 (permalink)
Old 10-15-2005, 07:02 PM
1935 Ford pickup
Talking Methanol cost.
I pay $1.38 a gallon for my methanol true, BUT I by 300 gal totes twice a month on a commercial account, so I get wholesale pricing. In order to pickup 300 totes you MUST HAVE a CDL with Haz-Mat endorsement, which I do have.
Even though You are paying twice as much as I am It is still cheaper than $3.00 a gallon dino-diesel!! Good luck on your system! FABMANDELUX.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
