How to remove and replace brake light switch - Ford Truck Enthusiasts Forums
Old 10-11-2005, 11:43 PM
Bill5638 Bill5638 is offline
Bill5638 is starting off with a positive reputation.
Smile How to remove and replace brake light switch
How to remove and replace brake light switch F150 XLT 2001
Old 10-13-2005, 01:21 PM
lancekilgore lancekilgore is offline
lancekilgore is starting off with a positive reputation.
did resolve the issue yet. It should unbolt and bolt the new one in, make sure the adjustment stays the same (if there is one). pretty simple
Lance
lt green wire @ brake switch is grounded? EVERYTHING works though, BUT trailer brakes... maddmatt02 1987 - 1996 F150 & Larger F-Series Trucks 7 08-09-2015 05:23 AM
Brake Light Switch Issue Technoblake 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-08-2014 06:09 PM
03 Sport Trac Headlight Switch maxndano Explorer, Sport Trac, Mountaineer & Aviator 4 03-31-2014 07:37 AM
03 explorer brake light switch 94fordtruck Explorer, Sport Trac, Mountaineer & Aviator 4 05-09-2008 10:03 AM
Parking Brake Light Stays On Traildust 1999 to 2016 Super Duty 9 09-01-2006 06:46 AM
Tags
1997, 1999, 2001, 2004, 97, brake, break, change, f150, ford, light, remove, replace, stop, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
