6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Oil for 2007 and future
Old 10-11-2005, 07:52 PM
bnmccoy's Avatar
bnmccoy
bnmccoy is offline
Good reading regarding new future class of oil. Note the warnings (near end of article) regarding use of new oil only with the new ULS fuel.
http://www.acppubs.com/index.asp?lay...cleID=CA511331
Old 10-11-2005, 08:39 PM
Flash's Avatar
Flash
Flash is offline
In regards to the low sulphur fuel, there are going to be a lot of folks replacing injectors on their diesels prematurely and often. Sulphur is relied upon to lube the injector. Reducing the amount from 500 ppms to 15 ppms is going to have the old style injectors hammering themselves into worthless metal. I believe the 6.0 injectors will not have as much of a problem as the older 7.3 or 6.9. Unless they come up with a fuel additive for lubrication, it's gonna get expensive to drive a diesel. The good news, the newer engines will last longer and run cleaner. It will also open up a new market for clean diesel engines in a variety of sizes including one for the Ranger and the F-150.
Old 10-12-2005, 12:17 AM
BigF350's Avatar
BigF350
BigF350 is offline
We have low sulphur diesel here (Australia) - its currently 50ppm, going to 10ppm in 2008 (I think).
There have been NO problems as far as I am aware with the 7.3l (we still get that here).
I personally only see sulphur as a bad thing - it is very corrosive, killing engine life and emissions.
Old 10-12-2005, 01:00 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
sulfer is a good anti wear lube it performs well under stress and lubes well. there is a few cetane boosts that have big amounts of sulfer in them. just like when leaded gas went away a company came out with lead substitute i think you will see someone selling sulfer boost.
Old 10-12-2005, 01:26 AM
BigF350's Avatar
BigF350
BigF350 is offline
You are correct, sulphur does have good attributes.
Just I am not sold on it.
strokin'_tatsch
76
06-15-2018 05:27 AM
bnmccoy
3.0L Powerstroke Diesel
52
06-11-2015 11:07 AM
Red Star
Ford vs The Competition
95
05-19-2007 06:53 PM
Firemnhoser
General Diesel Discussion
22
10-29-2005 09:34 PM
Logical Heritic
45
09-09-2004 08:43 PM
Quick Reply: Oil for 2007 and future
