What happens if differential oil level is low or very old? - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Old 10-11-2005, 10:19 AM
RickPlmr RickPlmr is offline
RickPlmr is starting off with a positive reputation.
Question What happens if differential oil level is low or very old?
What kind of damage would these situations cause? Would the differential lock up, or start making noise, or vibrating?
Old 10-11-2005, 12:12 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
Very low oil can cause lack of lubrication which leads to all sorts of nasty things. The limited slip clutches may wear, the gears may go, the bearings may disintegrate. All very bad.
Old oil kind of depends. Do you mean drity grungy worn out oil or just clean oil that has been in there a long time.
Dirty grungy etc, has the same problems maybe worse, as low oil.
Old oil kind of depends on how old. A few years is probably OK as long as the diff has been kept out of standing water and lots of dirt. I would image diff fluid that has been around 20 30 years might "gel up" which would be a problem, but I would not expect this for most diffs kept in a clean environment without a lot of heat.
In any case, to be safe I would change the oil. If in doubt change it, diff fluid is cheap.
Good Luck,
Jim Henderson
bradcdavis00 bradcdavis00 is offline
bradcdavis00 is starting off with a positive reputation.
If you have a limited slip differential and do not change the oil often enough the XL-3 friction modifier additive can wear out. Then the clutch pack goes bad and has to be replaced. You can tell this is begining to happen when you get shuddering on turns. This happened to me, thats how I know.
Old 01-11-2017, 01:20 AM
John Ricci John Ricci is offline
John Ricci is starting off with a positive reputation.
Maybe you can help me
I am having the same issue you had however I own a 00 Silverado. Did you have to replace the whole rear end? Also do you have some tips to try before replacing anything? Any info will help.
Quote:
Old 01-13-2017, 09:50 AM
onug's Avatar
onug onug is offline
onug is gaining momentum as a positive member of FTE.onug is gaining momentum as a positive member of FTE.
I'd pop the back cover off the diff and look for damage and uneven wear. At minimum replace the fluid and see if that fixes any issues.
Differential Identification steam643 General Automotive Discussion 4 05-05-2016 04:45 PM
Differential Fluids for 1980 F-100 4X4 GMCPic Oil & Lubrication 3 05-26-2013 02:02 PM
Differential? jwhopson Expedition & Navigator 22 04-07-2011 08:22 AM
Differential Gear Oil for Dana 50? anojones 1987 - 1996 F150 & Larger F-Series Trucks 3 04-10-2009 04:57 PM
diff cover stickittoem General Diesel Discussion 2 03-07-2008 10:46 PM
Tags
axle, bad, change, differential, explorer, fluid, ford, hum, low, lsd, noise, oil, real, signs, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
