Lift Kits - Page 5 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
View Poll Results: What lift kit manufacturer do you use?
CST 2 0.35%
Donahoe Racing 130 22.57%
Fabtech 72 12.50%
Pro Comp 105 18.23%
Rubicon Express 6 1.04%
Skyjacker 75 13.02%
Superlift 72 12.50%
Other 114 19.79%
Voters: 576. You may not vote on this poll
Lift Kits
  #61
Old 02-24-2006, 01:38 PM
Bear Hunter's Avatar
Bear Hunter Bear Hunter is offline
Bear Hunter is gaining momentum as a positive member of FTE.Bear Hunter is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Antacus
My friend has an older 350 that he has a 5th wheel on. Right now my truck is right at the same height as his, maybe an 1" lower. He has 16" wheels and 2" blocks. I got 17" wheels and no blocks... having said that I'll have to measure to verify. That is red neck measurin, leaning over the bed sides to open the cooler which gets less accurate over time
Yeah...wheel size really doesn't have anything to do with lift height...it's the size of the tires that adds to a suspension lift.
  #62
Old 02-27-2006, 07:22 AM
mein2xshp's Avatar
mein2xshp mein2xshp is offline
mein2xshp is starting off with a positive reputation.
Just want to let someone if they go an lift your SD don't do what i did, don't get the cheap one i found on e-bay (rough country) it works and looks good but the ride sucks. I am looking for another one to replace this in the spring. As far as shocks i still have the stock ones but have the dual Skyjacker steer stab, that i like, you get abolutely no shimmy or shake in the steering wheel when hitting the wonderful pot holes in the northeast. Anyway i hope some of this helped the next guy behind me making these beautiful trucks look even better.
  #63
Old 02-27-2006, 07:37 AM
marv02's Avatar
marv02 marv02 is offline
marv02 is starting off with a positive reputation.
stay away
Quote:
I dont know what year you'r turck is mine is a 2002 with 5.4 stay away from Pro Comp It has a rough ride also I had other lift kits in the past that rode much better.
Before you change you'r springs try a higher end shock that will make a big diffrents in you ride, I am running Bilstiens Love the shocks, E-Bay is the place to get them $259.00 OTD.
One more thing as my spring get some age on them they are breaking in and giving a better ride not the best but better.
  #64
Old 03-04-2006, 07:06 PM
Square Grouper's Avatar
Square Grouper Square Grouper is offline
Square Grouper is starting off with a positive reputation.
Talking
Do lifts affect your warranty at all? I'm getting tired of the stock look and need something more aggressive.
  #65
Old 03-05-2006, 12:17 PM
Kadukoboy Kadukoboy is offline
Kadukoboy is starting off with a positive reputation.
Quote:
Yes...I've heard horror stories that dealerships will completely void the warranty (if they're arsses about it)
Mostly they won't warranty anything in regards to suspension, axles and possibly the transfer case
  #66
Old 03-06-2006, 02:56 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03 SoCalSuperDuty03 is offline
SoCalSuperDuty03 is gaining momentum as a positive member of FTE.SoCalSuperDuty03 is gaining momentum as a positive member of FTE.
'03 SD Shortbed Crewcab 6.0
1-8" DR, Deaver springs
2-5" Deaver, 1" billet aluminum block
3-Fox Reservoirs, 11" front, 14" rears, Fox Damper
4-38x15.50x18 Toyo Open Country M/T's
5-4.30's, Detroit Locker
6-Self
7-Awesome quality, decent ride, handles excellent on the street or off road
8-Nothing
9-A Grip, even at Jobber or less
Tim
  #67
Old 03-06-2006, 06:56 AM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE.cangim is gaining momentum as a positive member of FTE.
Look at it this way, if the dealer can blame the problem on the aftermarket parts, be suspension or power mods, then they are going to blame the parts and not warranty your rig, how far they stretch it, will depend on the dealer. If you get there at the start of a quarter when they are on a fresh budget for warranty repairs, you are less likely to get gruff, towards the end, when they are over budget, you bet they are going to try to get out of it if possible.
  #68
Old 03-06-2006, 08:42 AM
BFR250SD's Avatar
BFR250SD BFR250SD is offline
BFR250SD has a good reputation on FTE.BFR250SD has a good reputation on FTE.
STOP with the warranty debates!
This has happened a million times. Don't do it here! This thread is for info on the lift kits, not to have a warranty debate.
If that's what you want to do, DO A SEARCH! It has happened before and most have gotten locked.
Thanks,
BFR
  #69
Old 03-12-2006, 09:48 AM
Bruce F250 Bruce F250 is offline
Bruce F250 is starting off with a positive reputation.
Ok guys I need some imput.
I just installed BFG/305s on MT Classic locks, on my 250. It looks so much better over the stock tires/wheels. However, Im getting a little rub at full lock. What do you recommend? F350 4 inch blocks and a leveling kit, a 2 inch lift, or a 4 inch lift? Im thinking 4 inch just incase I decide to go with bigger tires in the future.
  #70
Old 03-12-2006, 10:15 AM
marv02's Avatar
Rubbing
Bruce
Check you'r wheel off set if you have a 4X4 you should not rub with 305"s my 2002 f 250 4X4 have 315 on it with out a lift and yes they rubbed they still do with a 6 inch lift at full lock it's the wheel off set.
  #71
Old 03-12-2006, 10:21 AM
I'll check it out. it would suk if i had to get different wheels. My 250 is 04. dont know if any different from 02
thanks
  #72
Old 03-12-2006, 11:25 AM
EnviroCon EnviroCon is offline
EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.
Quote:
Originally Posted by marv02
Bruce
Marv's right if the rubbing is on anything but the fender or bumper. A lift will only move those 2 items out of the way. If it's rubbing on the springs then you have a couple of options. Get a wheel with less backspacing or drill and tap a hole in the wheel stop on the back of the hub. Then put a bolt in there and adjust it so the wheel doesn't hit the spring. Unfortunately, the bolt method also reduces the turning radius.
  #73
Old 03-12-2006, 11:26 AM
marv02's Avatar
Off set
thanks
I read some where In this form that the truck needs some thing like a 4.25 or 4.50 back space off set I just been living with the tire rubbing just turn lock to lock then once agian how offen do you turn lock to lock.
Living with the noise is lot cheeper than new wheels.
  #74
Old 03-12-2006, 11:30 AM
its only rubbing on the plastic shroud in the well.
  #75
Old 03-12-2006, 11:39 AM
Well then. A leveling kit and a 2" kit are pretty much the same. A 4"-4.5" spring hanger kit is a good way to go if you want to keep the stock spring ride and think you may want to go higher in the future. But a leveling kit is much cheaper and easier to install. Either of these kits will solve your rubbing problem.
'97 f250 PSD w/ "rebuilt" title HKmnU97 1994.5 - 1997 7.3L Power Stroke Diesel 28 08-15-2014 05:04 PM
1949 F4 Rockabilly4ever 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 03-20-2012 07:54 PM
ALL TEXAS CHAPTER GTG/ AUGUST plumber01 Texas Chapter 104 09-05-2010 01:58 PM
Wide open barn doors eatfish Excursion - King of SUVs 5 05-13-2008 08:40 PM
Installing a Newer OEM radio in my truck timsvtgen1 1997 - 2003 F150 0 03-18-2008 07:36 PM
Tags
16, 315, 31565, 35s, 38x1450x16, 45, 65, accomodates, equivalent, f350, kit, lift, size, superduty, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
