Lift Kits - Page 13 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
View Poll Results: What lift kit manufacturer do you use?
CST 2 0.35%
Donahoe Racing 130 22.57%
Fabtech 72 12.50%
Pro Comp 105 18.23%
Rubicon Express 6 1.04%
Skyjacker 75 13.02%
Superlift 72 12.50%
Other 114 19.79%
Voters: 576. You may not vote on this poll
Lift Kits
  #181
Old 02-08-2014, 11:30 PM
mtgrzlyman's Avatar
mtgrzlyman mtgrzlyman is offline
mtgrzlyman is starting off with a positive reputation.
Don't get BDS there warranty and customer service sucks! Also rides like a cheap kit! These guys suck
  #182
Old 02-23-2014, 03:08 AM
my60merc's Avatar
my60merc my60merc is offline
my60merc is starting off with a positive reputation.
I recently installed a 6" lift on my 2000 F250 2wd 7.3 Crew Cab long bed. The kit is supposed to clear a 315 with minor trimming but I don't want to change my gearing when I tow. I will be running a 285 or 295. My only complaint is the truck not sitting level. There might be some people that like the pre-runner look but I don't.
1. 6" Fabtech Basic Kit
2. 3" blocks that came with the kit (Fabtech seems to likes the pre-runner look)
3. Fabtech Performance shock
4. I'm looking at Hankook Dynapro MT 285/75/16
5. I think I have 4.10's
6. Self install
6a. Took my time and replaced all front end parts while I had it apart. Ball joints, axle pivot bushings, radius arm bushings, etc. Lift install was the easy part, pivot bushings kicked my butt.
7. My truck rides smoother now. I don't like the rear of the truck sitting lower. I will be installing a taller block so that it sits level.
8. I would have liked a taller block to be included.
9. About $1100
  #183
Old 02-23-2014, 04:21 PM
mtgrzlyman's Avatar
Just be glad you didn't end up with the mess I did BDS is the biggest pile lift I ever had then they lie about tire clearance and warranty! I wish I had fab tech just buy some different blocks and your set!
  #184
Old 10-27-2014, 09:04 PM
tazaxx's Avatar
tazaxx tazaxx is offline
tazaxx is gaining momentum as a positive member of FTE.tazaxx is gaining momentum as a positive member of FTE.
Quote:
All the pro 4x4 shops here in southern Virginia recommend BDS suspension for the quality of the components as well as the lifetime warranty.... So tell us how your kit was installed, and what exactly happened??
I'm planning an 8" BDS on my Superduty, and not really considering any other manufacturers.
  #185
Old 10-28-2014, 11:07 AM
figurhead's Avatar
figurhead figurhead is offline
figurhead is starting off with a positive reputation.
ICON Performance Suspension Systems, Coil-Over Shocks, Uniball Upper Control Arms, and Lift Kits for Trucks and Suv's
The lifts used to be Donahoe Racing, but Donahoe sold this division off to Icon. I went to high school with Kreg Donahoe, but he's not running the business anymore.....not going there. You can google him, if so desired.
I have an Icon lift on my truck, 10.5", and my neighbor's company powder coats Icon parts, here is SoCal. Very sturdy, built to last. He tells me about comparing Fabtech's with Icon's: not even comparable.
I have some Fabtech torsion bars on my truck; which is pretty built. I have ripped a bung out, broke them in half, and the boxes on the axles, even after welding them, I have ripped them apart. Fabtech did get me some new better built boxes at cost, which I appreciate. I extended the bars and welded solid bars inside, and strengthened them. They (Fabtech) are nice for show trucks, but do not hold up to real power or off roading, at least in my experience.
'97 f250 PSD w/ "rebuilt" title HKmnU97 1994.5 - 1997 7.3L Power Stroke Diesel 28 08-15-2014 05:04 PM
1949 F4 Rockabilly4ever 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 03-20-2012 07:54 PM
ALL TEXAS CHAPTER GTG/ AUGUST plumber01 Texas Chapter 104 09-05-2010 01:58 PM
Wide open barn doors eatfish Excursion - King of SUVs 5 05-13-2008 08:40 PM
Installing a Newer OEM radio in my truck timsvtgen1 1997 - 2003 F150 0 03-18-2008 07:36 PM
Tags
16, 315, 31565, 35s, 38x1450x16, 45, 65, accomodates, equivalent, f350, kit, lift, size, superduty, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
