using alot of fuel
Old 10-18-2005, 02:08 AM
Never Done's Avatar
Never Done
Never Done is offline
using alot of fuel
hi there, i just purchased a 83 ranger for a winter truck while i park my 93 f350 crew. the ranger seems to go thru alot of fuel, the exhaust smells really rich. i'm wondering if these rangers get good milege. (it has a 2.3l according to the valve cover spec decal, the previous owner said 2.0l) i'm use to diesel. just wondering on tips that might help. Thanks
Old 10-18-2005, 06:20 AM
tomw's Avatar
tomw
tomw is offline
You should get (2WD-manual) in the mid to high 20's with reasonable use. You probably have the famous sinking float in your carb. Those had a black 'plastic' float that would get saturated, and raise the level in the float bowl, thus allowing more fuel than normal to get used. Check a local parts store for a replacement, after you check the static fuel level in the bowl. The 2.0 just needs to be bored out, but I don't think they made them until 1985 when they were trying to (i think) get their fleet average mpg up.
Just my 2 cents.
tom
steve33444
67
02-19-2015 06:36 PM
Never Done
Bronco II
08-29-2012 07:22 PM
Shirk98150
1983 - 2012 Ranger & B-Series
03-28-2011 04:36 PM
BADBLUEOVAL351
4 Cylinder Engines
02-06-2008 01:49 PM
Finstababy
06-10-2007 08:57 PM
Quick Reply: using alot of fuel
