ABS sensor
It is on top on the front wheel bearing hub assembly. To access it, you need to remove the brake caliper, caliper bracket, splash shield. One hex screw holding the ABS sensor. The sensor is all plastic, an O ring on the sensor body, so it is a tight fit in the hole. Spray lots of liquid wrench around it before attemp to remove it.
Clean the mounting surface with wire brush, apply grease before install.
RobertGordon
03-06-2004 08:22 PM
