gross vehicle weight - Ford Truck Enthusiasts Forums
Old 06-05-2002, 07:18 PM
Gord Gord is offline
Gord is starting off with a positive reputation.
the door jam tag on my 79 f-250 says my GVW is 7400lb/3356kg. i want it to be higher. what constitutes an increase in a vehcile's GVR? more leaf springs, for one i'm sure. but do the axles and the frame come into play when defining a GVW? any help is appreciated!
Old 06-05-2002, 07:22 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
All you have to do is look at an f350. Heavier frame, more springs, larger differentials, larger rims and tires (sometimes dually).
Old 06-06-2002, 12:55 AM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
The highest GVW from the factory is 7900lb/3583kg for a '79 F250 Regular Cab. The difference between that and yours is all in the rear springs.
Old 06-06-2002, 01:48 AM
WC76TX WC76TX is offline
WC76TX is starting off with a positive reputation.
BBB are you sure on that 7900 lbs being the highest on a F-250?
my 1975 F-250 camper special shows 8100 lbs. is it just the diffrence in years and springs?
Will
Old 06-06-2002, 08:33 AM
russellkr russellkr is offline
russellkr is starting off with a positive reputation.
my 76 f-250 camper special says 8600lbs
but part of the gvw is determined by what you can stop, the camper specials have dual piston caliper front breaks and heavy drums in the back
Old 06-06-2002, 11:02 AM
BB's Avatar
BB BB is offline
I'll have to go back and look at the Camper Special models.
Barry
Old 06-07-2002, 12:42 AM
BB's Avatar
BB BB is offline
Well I looked at the Camper Special models and they seem to have the same maximum GVW as the Regular Cabs could have.
Here's the breakdown for max. GVW for the F250 Regular Cab including the Camper Special:
'73 - 8100lb.
'74 - 8100lb.
'75 - 8100lb.
'76 - 8000lb.
'77 - 7900lb.
'78 - 7900lb.
'79 - 7900lb.
Only problem is, it doesn't agree with what you got.
So much for advertising.
Barry
Old 06-07-2002, 10:30 AM
hawkrod hawkrod is offline
hawkrod is starting off with a positive reputation.
Closed knuckle front end differences Amphihauler 1961 - 1966 F-100 & Larger F-Series Trucks 1 09-21-2016 04:28 PM
05 4x4 8200 GVW - Rancho Quicklift wont work? bayareajim 2004 - 2008 F150 0 04-20-2016 12:56 AM
GVW questions... GAHIGHRIDER 1967 - 1972 F-100 & Larger F-Series Trucks 7 07-09-2015 12:50 PM
Re-Register my truck, opinions? sandyc 6.7L Power Stroke Diesel 41 02-28-2015 06:01 PM
Which ECU should I use? abelmoreno Ford Inline Six, 200, 250, 4.9L / 300 8 08-10-2005 01:27 AM
Tags
1977, 1997, 79, 8100, deisel, diesel, f100, f250, f350, ford, gross, gvw, maximum, specs, truck, vehicle, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
