Spring eye pin removal on 48 rear (subtitle: how do you get the dang thing out)
48 F1 - On the rear leaf springs, how do you remove the spring eye pin from the spring hanger? (the one with the frame crossmember in the way).
I was able to punch out the rear one, but the front pin on the rear leaf spring has the crossmember blocking the hole. And I was just starting to make some progress again....
What has worked for everyone else that has torn theirs apart?
Thanks
Thanks
Oscar,
The previous owner must have had some problems with mine in the past, there were some cleverly placed (but danged ugly) holes torched in the crossmember so I could actually get a punch in there to bang them out. It would have been nice if the previous owner would have torched the holes in line with the pins....
....previous owners...gotta luv 'em (yea right)
Bobby
Bobby
Bill's method is the most common, but you need to make sure there is absolutely no weight or force on the pin. They get grooved and are pretty stubborn. A slide hammer really helps.
Since you clearly want to replace it anyway, before you break out the "hot wrench", try a sawzall or a bare hacksaw blade and just cut through it on each side of the spring. With a sawzall it goes quickly, by hand you'll be sore. But then the spring will drop down with part of it inside, and the other pieces can be driven out.
Mine came out pretty easy. I had already removed the bed. That made it very easy to get a good swing at them. Take the back ones out first and have a helper "wiggle" the spring pac while you wail away. (use a quality punch and wear your safety glasses) Soakem with your favorite break free spray before you begin and good luck.
Later...Randy
Later...Randy
Hey...You gotta think with a handle like "REAMER" he's GOT to know what he's talking about!!!
My 54 had the holes thru the frame as well, I soaked with several doses of penatrant....then a brass drift and a two pound hammer and away you go.
Sears sell a three piece drift set for apx. $18.00, but any auto parts house should have one.
And go ahead and plan what words your gonna say when you hit your hand with the hammer....cause you know its gonna happen. "#@!#*???...truck"
good luck with it, Ed
here's a thought, put the drift into an air hammer and coax it loose!!!?
I got it!!!!
Thanks for all the ideas.
I had the bed off already. I removed the u-bolts from the axle (almost no weight on the leaf spring pack).
My crossmember did not have an access hole already there, so I was hesitant of making a new hole.
I don't have a slide hammer.
Not sure what a drift is, but I am guessing it is the equivalant of a punch.
My son (age 12) and I sat out there looking at it and discussing what to do. He already handy with the tools.
I finally decided to try to "loosen" the pin by turing the grease zert beyond maximum tightness. I was not sure that would do anything except break off the grease zert and then make the pin unusable, but I have extra pins from my parts truck.
I turned her and turned her .... and the pin spun.
Still wasn't sure that would help anything, but I put my fence tool (what do you know, farming tools work on autos too) between the vice grip I was using to turn the zert and the spring hanger and pried a bit. It started inching out.
I was able to pry and tap the vice grip until the spring pin came out.
I don't know that it helped, but it couldn't have hurt. We had shove fresh grease into the zert about a month ago.
Oscar V. Zerk
Born: May 16, 1878 in Vienna. Died: December 8, 1968 in Kenosha. World-famous inventor. He patented over 300 inventions, including leg-slimming hosiery, quick-freezing ice cube trays, spatterproof nail brushes, fail-save brakes for trolley cars, vibration-free camera tripods, oil well recovery systems, and refrigerators for cars. His greatest invention, however, was the Zerk grease fitting, a lubrication system which became the basis for those used on every car, truck, and plane. At the time of his death in 1968, an estimated 20 billion fittings had been manufactured
Originally Posted by Bill50
What I did was remove the grease fitting and then put in a bolt and used that to pull the pin out.
Good luck
Bill
Good luck
Bill
Carl
