92 f-150 with 302 swapping to a carb couple questions
This is my first post here and I'm going to resurrect this thread because I'm doing the same thing as 92flareside. I have a '94 Mustang motor that I want to put into my '92 F-150 4WD with E4OD transmission and run it with a carb. This is not my daily driver and over the next several years it will be an on-going project. Yes, EFI is better and at some point in the future I will do the mass air conversion. In the meantime I need to get this truck running before ordinance enforcement notices.
It looks like I'm going to have to use the truck oil pan, timing cover and accessories. Does anyone know if the '92 302 engine is a 50 oz imbalance or will I need a new flexplate? I will also need to get a fuel pressure regulator with a return outlet to reduce the fuel pressure and get a distributor with either vacuum or mechanical advance.
Have I overlooked something? Thanks for any help you can give.
If you are going to mass air later, why go to all the trouble of converting to carb in the first place? I'm not trying to be rude, but I just think it would be easier to save the trouble of converting to carb if a year from now go through the trouble to un-do it. How are you planning on controlling the transmission with a carburetor (the E4OD is controlled by the engine computer). Although, are you sure it isn't an AOD? If it is, that's one less thing to worry about since it is not computer controlled.
If someone has a VEX1 or WAY1 computer and wiring harness laying around that they would sell me cheap, I would go that way.
As far as the transmission it has the 20 bolt pan so it would be an E4OD. Please correct me if I'm wrong, my understanding is that if I left the stock computer in, the trans would still function. I read an article about a mass air conversion at www.fordmuscle.com/archives/2005/10/MassAirConversion/index.php that said (just above the reference to this forum) some E4OD owners run a Mustang computer to handle the engine functions and keep the speed density computer for transmission function. I would assume that the VSS and maybe the MAP sensors give the computer the speed and load info?
I found out that the 302 engine is a 28 oz imbalance so I need to use my HO motor balancer.
I'm not really sure exactly what sensors are needed to control the transmission in stand alone form. It can be done, but I really don't know what all is involved with that. What is wrong with the truck electronics now? I think the carb conversion is do-able if that's what you decide to do.
92BroncoMan
1978 - 1996 Big Bronco
05-01-2016 09:51 PM
302, 92, carb, carbureted, carburetor, converting, f150, issues, motor, oil, pressure, put, speed, swapping, switch, tb, transmission
