Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-09-2005, 04:50 PM
onioncasserole onioncasserole is offline
Garage is empty, add now
onioncasserole is starting off with a positive reputation.
Biodiesel ignition Q's
From what I understand when using Biodiesel in your engine you have to retard the timing 2-3 degrees. Why? Can you overcome this by using a hotter ignition system?
  #2 (permalink)
Old 10-09-2005, 05:02 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
1996 Ford F-250
My Garage
444dieselrod is gaining momentum as a positive member of FTE.
I have never heard that. so far no one has had any issue with out retarding the timeing that I know of.
maybe because the way bio is made, any residual methane jacks with the timing and retarding it will counter act it.
just speculations....
Diesel Rod
__________________
'96 F250, Reg Cab 7.3 PSD, Auto, 4x4, XLT.
'97 F250, Ext Cab 7.3 PSD, Auto, 4x4, XLT.
'96 F250, Crew Cab 7.3 PSD, 5-SPD, 4x4, XLT.
'99 Jetta TDI, 5-SPD
'87 359 Peterbilt SHORT HOOD, 36" sleeper. 13 speed, 425 intercooled Cat.
  #3 (permalink)
Old 10-10-2005, 06:29 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Quote:
I can't answer about the timing, but last I knew, there was no ignition in a diesel, only glow plugs or preheaters, which only are used for cold starts. Compression creates heat, and the heat is what ignites the fuel, so there is no adjustment that can be made to control when the ignition would happen, only when the fuel is injected...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #4 (permalink)
Old 10-10-2005, 10:31 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Talking IP Timing
The only reason to retard IP timing is to lower NOX emissions. Biodiesel is an oxygenated fuel with a higher cetain rating than dinodiesel, It will generaly raise cyl temp by 50-100 deg , raising NOX emissions. By retarding 2-3 deg it will lower emissions. But it isn't required. FABMANDELUX.
  #5 (permalink)
Old 10-10-2005, 08:00 PM
dogman's Avatar
dogman dogman is offline
dogman is starting off with a positive reputation.
Here is a site on biodiesel, are truck are going to it. www.hugrsystems.com
__________________
2008, F-250 SD, PSD
1999 jeep TJ
X-Trucker, heavy hauler
  #6 (permalink)
Old 10-10-2005, 09:26 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
FTE *******
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Quote:
Really?!
Any clue on what percent by mass of oxygen?
  #7 (permalink)
Old 10-10-2005, 11:05 PM
1935 Ford pickup
Talking
Quote:
Originally Posted by PSD 60L Fx4
Really?!
Depends on feedstock, approx 6 -10 percent. We had ours tested: 8.4 percent.FABMANDELUX.
  #8 (permalink)
Old 10-13-2005, 07:41 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Fabmandelux is the man when it comes to this stuff. Guys read up at biodiesel dot org and ask this man here, youll get it right
  #9 (permalink)
Old 10-23-2005, 07:22 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
No engine modifications are needed for the soy - biodiesel. go to www.biodiesel.org they have all the info you need.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #10 (permalink)
Old 10-24-2005, 08:44 PM
Brian460 Brian460 is offline
Brian460 is starting off with a positive reputation.
Brian Barker
I didn't really notice a power improvement but, my truck seems to consistently get 2 mpg better on B20 than straight dino. Which to me would indicate a small power gain which I would assume is from more BTU's per gallon.
__________________
'03 F-250 FX4 CC SB 6.0L Spartan Tunes, 4" Superlift, 4" Magnaflow, X-Monitor, 315/75/16, 4.30 gears
PSD Burnout
KD0FBK
  #11 (permalink)
Old 10-24-2005, 09:28 PM
1935 Ford pickup
Talking More BTU's?
Quote:
Actually the btu value is slightly LOWER than dinodiesel, but it is an oxygenated fuel, And has a higher CETANE RATING than dinodiesel. If it is made with hydrogenated oil it has hydrogen added, which makes the cetane rating even higher.FABMANDELUX.
  #12 (permalink)
Old 10-24-2005, 09:34 PM
Brian Barker
I didn't know that. I have been reading a lot of the post on alternative diesel it is very interesting.
__________________
PSD Burnout
KD0FBK
  #13 (permalink)
Old 10-25-2005, 06:35 PM
Yes the biodiesel from crystalflash @ 5% soy is 51 min cetane. VS 40-42 cetane for #2. Just like adding racing fuel to your car.
__________________
B5 soydiesel user
Sirius radio
  #14 (permalink)
Old 10-25-2005, 07:18 PM
1935 Ford pickup
Quote:
And canolla oil is even better at min of 68! FABMANDELUX.
Tags
biodiesel, ignition
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
